Goin to junkyard tommorow...
Old Jun 22, 2006 | 12:54 AM
afr5's Avatar
I have an '85 iroc-z that originally had a 5.0L HO carb motor, but now it has a 5.7L v8 out of a '79 camaro. I'm just wondering what *EXACTLY* I need to convert this engine to a 350 TPI like in the '87+ model years.
I've read through all the posts, but i couldn't quite find what i was looking for.
Old Jun 22, 2006 | 08:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can't make it "exactly" like the '87, because '79 doesn't have one-piece rear main seal, passenger-side dipstick, or roller lifter cam provision.
But, you can put '87-up heads on the '79 block, and a flat-tappet cam that is similar to the '87 L98 roller cam.
Otherwise, there isn't anything that would keep a '79 350 from acting like an '87-up L98.
Old Jun 22, 2006 | 12:02 PM
afr5's Avatar
Is the '87 350 better than the '79?
Old Jun 26, 2006 | 04:14 PM
five7kid's Avatar
Depends upon whether you like one-piece rear main seals (I do) and factory roller lifters (I do).
Casting and machining quality are often better in mid-80's up blocks vs. mid-70's to early-80's.
Old Jun 27, 2006 | 05:27 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
yeah but there is usually a big difference in price and miles
Old Jun 28, 2006 | 04:58 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I say stay carbed (non cc though), go open loop, and keep the electronic spark control from the LG4's ECM. There's really no reason to switch over to TPI, unless you're coming from TBI that is....
Seriously tho, consider staying carbed.
Old Jun 28, 2006 | 05:53 PM
five7kid's Avatar
Yes, the older having more miles, and with poor quality control you'll find the $600 you just spent on machining is down the drain unless you spend another $600 to fix the quality problems that didn't show up until after spending the intitial machining dollars . . .
Old Jun 28, 2006 | 06:46 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
glad the new 350 i'm building is a late model 350! (1994ish pickup truck 4bolt main 350 roller motor, YEAH!)
Old Jun 28, 2006 | 10:22 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
word
armybyrd
Sep 28, 2023 12:16 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
S10K20
Oct 7, 2015 06:45 PM
Damon
Sep 26, 2015 04:29 PM
