Some Newbie questions 383 stroker
Car: 1989 camaro IROC-Z G92
Engine: GM 355
Transmission: Mad Dog 700R4
Axle/Gears: 3.27 :(
cccccccccccc
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
A BBC swap may be a little over your head. The jump off the line has way more to do with tires and suspesion setup than the transmission.
All the power in the world will do you no good unless you can plant it.
Engine: GM 355
Axle/Gears: 3.27 :(
the engine swap and im still not quite sure, will i need a new tranny if i get a 383 stroker?
Car: 86 Trans Am
Engine: 406
Depends on 1000 different factors. If you said the hp, mileage and driveability you are looking for we'll be able to help you out more.
Engine: GM 355
Axle/Gears: 3.27 :(
um, i want it to have somewhere around 350 hp and not super high milieage but not brand new, something that i can get alot of power out of and still have plenty of life left in , i was looking and i think some people have some for sale so i would consider buying one of those but what else would i need to make the swap? thanks u guys have been so helpfull
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Hmm,let's see. I have about 3500$ invested into a motor(383) that isn't even a motor yet.( crank,rods,pistons,heads,HSR only!) The sky is the limit! If money is not an object...go NASCAR!
Engine: GM 355
Axle/Gears: 3.27 :(
haha money is an object i was jw how long it would take me to save up enough to do the job, $3,500 is alot of oil changes for me haha (i work at a lightning lube) so it will take me a little while to save up, you guys think it would be cheaper to get a used complete one so i wouldnt have to mess with all that?, also will the 383 bolt up right to the stock tranny thanks
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
a 383 is just a 350 with a 3.75" stroke.(the stroke of the crank found in 400 sbc's) it will bolt up just like any other small block chevy.
i'd say if your gonna build one, to save up around $3K to do it...then get ready to spend about $2k on a tranny/converter that will hold it...then another $750 or so on parts to beef up the rearend...that is if you build the rearend and motor yourself...the $2K for the tranny would include assembly, but not installation.
but before you start throwing power at this car, get a set of subframe connectors, and get the rear suspension taken car of...and go ahead and build the rearend to hold the power and put in a set of gears that will work with your combo.
Engine: GM 355
Axle/Gears: 3.27 :(
ok ok, yea i was looking and there is the 700r4 street strip rebuild kit by probuilt automatics i was thinking of getting that iss about $500 roughly and it handles more than enough power, will i still have to get a converter?, also do you reccomend any places online i could get the subframe connectors and the rear suspension?, sorry i am completely new to this but i will have help when i install everything, im 16 and this is my first car but im going to bocces next year for auto tech and i will be learning alot there, im really excited to do this project, thanks you guys have been so much help
Engine: 7.0L
BMR Fabrication Inc.
or
Spohn Performance, Inc.
both of those will will have some excellent rear suspension pieces and subframe connectors.
as far at the converter/tranny, yes, you need to get a converter that matches the combo and i doubt you'll be able to find a 700r4 for $500 that will do the job. normally, for a GOOD tranny/converter combo, get ready to drop between $2000-$2500. if you can get away without OD and run a th350, you can get something to handle the power for less, but streetability without OD is a concern as well as getting a torque arm to work with it.
or
Engine: GM 355
Axle/Gears: 3.27 :(
thank you so much, I went ahead and orderd the subframe connectors and my unlce can go ahead and weld those in for me. im so excited!, also if i get this kit Performance Transmissions–specializing on 700r4 and 4L60e
- 700R4 Rebuild Kit-Street/Strip= and then the converter il be all set right? thanks again
Engine: 7.0L
do you have all the special tools required to rebuild the tranny and a knowledgable person to do it for you for free? if so, rock on, do it to it! i've built several motors and rearends and whatnot and i still won't touch more than the valve body of a transmission.
Engine: GM 355
Axle/Gears: 3.27 :(
haha yea i know i know, i could install the transmission with some help but i would have it assembled by american transmission (its a place near me) but where can i find a converter and how much will that run me?, man this is an expensive hobby haha
Engine: 7.0L
yes it is!
the converter, i'm gonna tell you to spend your money once and get a nice one from Edge, Yank, ATI, or BTE...though get ready to drop between $600-$850
