350 H.O. swap from 305/carb
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
i want to swap a 350 h.o. into my 91 rs. it currently has a 305 with a edelbrock carb. so i already have my ecm stuff removed, msd distributor, new fuel pump, etc. my question is, can i swap my serpentine setup from the 305? which harmonic damper should i use? ive never swapped a motor before, but i know that the h.o is a 1 piece rear main seal, which is good cause it'll bolt right up to my t-5, but do i need to buy new bolts for that (for durability)? is 750cfm too much for that motor? any help would be appreciated.
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Im not sure about the belt system.I think it works.Someone please correct.The 750 is to big if you keep the stock cam in.A 750DP was way to much for my zz4.I think 600-650cfm would be good.
Engine: L98/TPI
Axle/Gears: 3.45
i was thinking the same as far as the carb selection. i really need an answer about these pulleys!
Transmission: 4L80E/4L80E
A 750 isn't too big, but with a manual transmission you'll want a double pumper. You need to size it based on the lowest RPMs at which you'll go WOT (there's a chart on Holley's website to determine that). Most likely, a 650 will be adequate and won't cause low RPM WOT problems.
You don't "need" new bolts for the flywheel or clutch, but it can't hurt.
The serp accessories will fit. You may have to drill & tap one hole in the passenger head - mount everything, mark the hole, take it off, drill & tap. If needed - I can't say I'm certain about that, but have heard of it on ZZ4's).
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some info about the 350 HO Deluxe that may be helpful. The motor is equipped with a 4160 600-cfm Holley with vac operated secondaries and electric choke. If you use headers, you'll need the ZZ4 dipstick: P/N 12551144 (Indicator), P/N 12551154 (Tube), P/N 09439930 (Bolt). I used GM's lightweight flywheel (14088646). On the HO Deluxe, the manual recommends the accessory drive brackets from a 96-98 L31 Chevy or GMC truck.
JamesC
JamesC
Good scoop, JC.
Most people assume "bigger is better", which isn't always the case, so the factory and Holley are nervous about misapplications, which is why the VS carbs exist and are suggested/supplied. But, with proper stall (the biggest problem with over-carburation), a DP will do just fine and perform better.
Now, does anyone know the difference between '88-'92 3rd gen accessory mounting and '96-'98 L31 Chevy or GMC truck accessory mounting????
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Originally Posted by JamesC
...you'll need the ZZ4 dipstick: P/N 12551144 (Indicator), P/N 12551154 (Tube), P/N 09439930 (Bolt)...
...thats 2 votes for the zz4 dipstick!
Originally Posted by big_nick_kgm
I LIKE TO HAVE A 350 HO WILL THAT WORK ON TPI AM LOOKING FOR 400 HP HELP
all in all, including tuning the thing, you'll drop a great deal more money trying to keep(or get, i didn't see if you already had tpi) a 350HO w/ tpi.
400HP out of a 350HO and TPI isn't going to happen, IMHO.
get an vortec RPM intake and a holley 650DP and call it a day. Then you can take the extra 1.5-2k you saved on TPI junk and get a new transmission...I know I need a new one now
Car: 1990 Chevy on 35's, 1991 Camaro
Engine: 350 TBI/ 355 Carb
Transmission: unfortunately a 700R4, 400
Axle/Gears: stock, not for long
carb
A lot of people think that carbs can be too big or too small but as long as you know what you're doing or paying somebody who really knows what they are doing, they can tune it so that you can't even tell the difference. I think that carb will be just fine as long as it is tuned right.
And as for the random tpi thing, I am trying to sell a tpi setup with everything from fuel rail to intake manifold for $350
305, 350, 700r, carb, chevrolet, chevy, difference, firebird, ho, installation, manual, serpentine, swap, tpi, transmissions, zz3
