305 tune port
Old Aug 6, 2006 | 08:47 PM
1986taman's Avatar
305 tune port
do any body know if a 305 tune port is a good motor
Old Aug 6, 2006 | 08:49 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Any motor can be a good motor. It all depends on how much time and money you are willing to put into it.
Old Aug 6, 2006 | 08:50 PM
1986taman's Avatar
is it known for any problums
Old Aug 6, 2006 | 09:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Define "problems".
Recalls? Consumer Reports rating? Early failure? Inadequate engineering? Inadequate performance? Excessively expensive to modify?
Need to know what you're after.
Old Aug 6, 2006 | 10:50 PM
1986taman's Avatar
pretty much all of those type of things
Old Aug 7, 2006 | 12:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes, it's a good motor.
Prone to valve stem oil seal leaks, just like all other SBC motors. Cheap easy fix.
Hard/Costly to modify for high RPM power, but is notorious for lots of torque, and throttle response.
Old Aug 7, 2006 | 12:38 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Sweetest looking Induction setup ever IMHO, but i'll stick w/ my holley!
Old Aug 7, 2006 | 04:27 PM
five7kid's Avatar
Originally Posted by Tobias05
Sweetest looking Induction setup ever IMHO...
Old Aug 7, 2006 | 05:18 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
yeah, those intake tubes sure look menacing!
Old Aug 16, 2006 | 11:44 AM
SlowCamaro88SC's Avatar
305's outside of this community, are junk motors. yeah they do the job, but a 350 is virtually the same, and does that same job alot better w/ 45 more cubes.
people here in this community are sensitive, so I won't call it junk, but if anyone is going to build a motor for there car for PERFORMANCE, there are better options if sticking with a Gen I small block.
Old Aug 16, 2006 | 02:56 PM
five7kid's Avatar
305's are junk (yes, you did say it).
TPI is junk.
Let's face it, pretty much everything the factory put out was junk with regard to performance (you can make a reasonable argument to the contrary with regard to LT1's and LS1's, but we're a 3rd gen Board here).
Regardless of what you start with, you are going to have to make serious modifications in order to get "real" performance out of it. But, that can be done with a 305, that can be done with TPI, and in some cases that may be your only choice (read: Emissions) unless you go with the aforementioned LT1 or LS1.
How "good" something is, or how close it is to being "junk", is really too subjective to be able to answer definitively.
Old Aug 16, 2006 | 06:02 PM
i can agree to that. it's just that outside of here nobody soups up a 305, unless it's a g-body.
there are a million combos you can run with, fuel injected or not.
I hate to be negative, but having a new GTO, and the old trans am, it just makes the shortcomings feel much stronger.
Old Aug 16, 2006 | 06:06 PM
Evil86Saleen's Avatar
Car: 1986 Saleen mustang.
Engine: Turbo 5.0.
Transmission: T5.
Axle/Gears: 3.55
Just wondering.
Why is it that a 305 is junk and yet Ford guys make 400+hp on a regular basis with a 302.
I know that the 302 rod to stroke ratio is a little better than a 305 but the displacement is the pretty much the same.
kyle
Old Aug 16, 2006 | 06:14 PM
five7kid's Avatar
The 5.0 is a 4" bore by 3" stroke engine vs. the 3.736" bore by 3.48" stroke of the 305 SBC. The heads have 4 bolts per cylinder vs. the 5 bolts per cylinder of the Gen I/II SBC, which keeps bolts from getting in the way of ports. Those two factors lead to better breathing in the 5.0 vs. the 305.
Ever heard of a 5.0 blowing a head gasket? Ever heard of a 5.0 block splitting down the middle? It's always a trade-off.
Old Aug 24, 2006 | 09:38 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Nah, Id take a Crossfire anyday over a TPI. They work good if you know what youre doing with them. I think they look way better too.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
355tpipickup
Aug 13, 2015 07:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
