chevy 400 swap
Old Aug 13, 2006 | 01:32 AM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
chevy 400 swap
Im planning to rebuild my newly acquired chevy 400 ci v8 (2.02 intake valves) (1971) and get it down in another third gen camaro . Now I know the flywheel is not the same one that those on 350's . My question is : Besides the flywheel , is there any engine parts that wont fit a 400 ?
-Golden Warrior
Old Aug 13, 2006 | 09:59 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
starter just did this swap everything else is a direct bolt on
Old Aug 13, 2006 | 10:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Harmonic damper has to be a weighted 400 piece.
Old Aug 13, 2006 | 10:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Externally, all SBC engines are the same from the tiny 262 to the 400. The 400 has an externally balanced crankshaft so it needs a special flexplate/flywheel and balancer. Other than that, any other SBC parts will bolt right on.
Gen 1 SBC parts that is.
The 400 never came with 2.02 valves. It was never produced as a performance engine. They all had poor casting, smogger heads.
A basic 400 is just a base to build a performance engine. Change heads, intake, camshaft and it doesn't take much to start building some power.
Old Aug 13, 2006 | 11:21 PM
golden's Avatar
Car: '89 Firebird
Thanks man , I thought they were 2.02's ... maybe I should re-mesure them . Nice car by the way .
Old Aug 14, 2006 | 09:42 AM
AlkyIROC's Avatar
Car: 87 IROC L98
That still doesn't mean it doesn't have 2.02's. A previous owner could have easily had bigger valves installed or replaced the heads. The difference between 1.94 and 2.02 isn't very much.
What's the casting number on the heads. When installing a different set of heads on a 400 block, the steam holes should be drilled out in the head.
Old Aug 15, 2006 | 12:33 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally Posted by Stephen 87 IROC
When installing a different set of heads on a 400 block, the steam holes MUST be drilled out in the head.
Fixed.
Old Aug 15, 2006 | 06:53 AM
golden's Avatar
Car: '89 Firebird
I dunno 'bout the heads but the block has a 509 casting ...
Old Aug 15, 2006 | 08:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
509 casting is the most popular 400 casting. It should be a 2 bolt block which is better. Get some main studs and it will be more than strong enough.
Old Aug 17, 2006 | 08:52 PM
golden's Avatar
Car: '89 Firebird
Why 2 bolts main would be better for a sbc 400 ?
Old Aug 18, 2006 | 12:06 AM
Air_Adam's Avatar
The 400 blocks didn't have the main webbing cast as beefy as the 4.0" bore blocks (350, 327, 302) did, so being drilled for the outter bolts actually weakens the casting more than it helps anything else. Splayed 4-bolt caps wouldn't be a bad idea though, but not needed unless you are making a rediculous amount of power (600 or better).
AussiePr0nCar
Mar 6, 2020 04:04 PM
xkingcodex
Feb 12, 2020 07:43 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
camaro71633
Sep 1, 2015 10:24 AM
theshackle
Aug 22, 2015 06:52 PM
