pollution gear?
Old Aug 23, 2006 | 12:22 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
pollution gear?
just took out my motor(305ho)was wondering if anyone would know if it would be better to get rid of all that pollution junk or should i leave it(all of it works)would i gain more performence from gettting rid out it or not?any reply would be good thanx
Z28er
Old Aug 23, 2006 | 03:42 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Personally, I would get rid of it. It is ugly and in the way.
However, it doesn't hurt your performance that much if at all.
the choice is yours. Your engine will run with or with out it just fine.
Old Aug 23, 2006 | 04:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it depends
if it is all intact and works fine then theres no real reason to not put it back, unless you dont have emissions inspections where you are and if you dont like the clutter of it all
its up to you, we cant answer for you, it is all up to your preference
good luck
Old Aug 23, 2006 | 07:04 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its all working, then its not hurting anything. You won't gain any power by removing it.
Old Aug 24, 2006 | 05:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm not a tree-hugger particularly, but if the equipement works and you loose nothing, why not keep it?
JamesC
Old Aug 24, 2006 | 07:12 AM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
thanx for tha answers guys.if it don't hurt my performence its gone,i just hate when i'm cleanning my engine bay and i have to wipe all those extra hoses and what not.
Old Aug 24, 2006 | 02:20 PM
Air_Adam's Avatar
The only thing gained by removing the smog equipment is just a 'simpler' engine compartment with more room to boot, and less that can potentially cause problems later. I removed mine because the previous owner started removing it, but did a hack job and didnt finish removing it. If he just left it all alone, and it was all somewhat functional, I probably would have just left it alone. At least, untill the car started turning into a race car anyway...
Old Aug 26, 2006 | 07:20 AM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
well i won't be doing a hack job,i'ts gonna be done right and everything will be gone,this cars my baby,just like a lot of cars on here is to ppl.if you don't do it right there no sense in doing it at all
Old Aug 26, 2006 | 04:03 PM
Air_Adam's Avatar
Agreed... all I'm saying though, is that if you are doing it in search of power, you will be disappointed. If its for esthetics or play room, then thats cool, I wouldn't argue with that.
Old Aug 26, 2006 | 04:33 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
cool
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
