supercharged fastburn 385 hot cam stock tpi or tpis stealth ram?
Old Oct 12, 2006 | 02:26 PM
cjmack's Avatar
i am putting a fastburn 385 hot cam motor in my 88 iroc. i understand stock tpi setup naturally asp will kill this motor so i will probably buy the ridiculously overpriced tpis setup.. i also have a procharger d1sc tpi blower setup. i was wondering if i needed to spend the money or just use the stock tpi if i supercharge. any problems supercharging this motor? any ideas would be greatly appreciated. also any ideas on headers for fastburn heads in a 3rd gen car? maf or map? dont mind converting if i have to. im lost> anyone done similar setup? this could turn into a pricey experiment. dont mind if it works.
Old Oct 12, 2006 | 07:22 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Even with a supercharger you still need an intake manifold that will match the power characteristics of the engine. Using a stock TPI intake will just boost the low end torque beyond usefulness and kill the top end of that engine.
Old Oct 12, 2006 | 08:00 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Have you looked into the HSR?
Old Oct 12, 2006 | 08:12 PM
cjmack's Avatar
thanks for the info. also fastburn 9.5/1. any problems running pump gas supercharged? 12lbs boost on similar motor.
Old Oct 12, 2006 | 09:24 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Personally, I would get the HT 383 if I were to supercharge.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
