Double check me 305 TBI to 350 TPI
Old Oct 19, 2006 | 06:27 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
So im buying a wrecked 1989 iroc with a MAF 350 TPI,
I plan on putting this into my 1989 RS vert. I just wanted to check and make sure i dont get any surprises. Since ill have both complete cars sitting right next to each other this should be easy. I plan to simply pull The TPI and yank the tranny off, then pull my TBI slap the t-5 on the TPI and slide it back in. I have the complete harness, ECU, fuel tank, exhaust so it should be relatively straightforward right ? I dont need to cut any wires or anything correct ?
Old Oct 20, 2006 | 12:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You won't need to cut any wires. However, if the fuel pump in the RS is the original factory unit, you'll probably need to drop the tank and put in a TPI pump. The reason I say "original factory unit" is some aftermarket replacements will use the TPI pump for TBI applications - works fine with TBI, but the factory TBI pump won't support TPI.
Old Oct 20, 2006 | 09:26 AM
91Z28's Avatar
Car: 91' Z28
Im not worried about dropping the tank and replacing it, ive done it so many times i could prob. do it in my sleep, ive done it about 5 times over the span of about 3 years
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
