2.8-5.7 (well, 5.9-6.0) Tranny Q
Old Nov 1, 2006 | 09:37 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Hey guys, i am building a 350 (well, 359-360 ... 350 bored .060 over) engine and i'm going to toss it into my 89' Camaro. It is a 78' engine from a race car. I am taking the block and putting almost everything new in it... except rods, rods are still great. Now, the Tranny Q... i know the v6 tranny 700r4 (auto) doesn't bolt right up to the v8. what company do you guys recommend for a bellhousing to bolt up and what type of bellhousing? or can anyone else explain a little more on what i need to do? I have searched already, do i need to search harder?
Oh yeah, it's going to from mpfi v6 to carb v8. i already have all of the info for fuel and most of the stuff for the computer that i know of... also i will need to put a shift kit in the trans - so that i don't have to use my computer... or do i need to modify the computer? I think the v8 used to use a powerglide trans... but i want to keep my 700r4 because i just got it rebuilt in march. i'm also putting vortec heads on it.
Old Nov 1, 2006 | 10:00 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I'm doing the 173-350 swap too, and from my research you'll either have to swap cases (your 700R4 guts to a V8 Case) or use a V8 700R4. If you swap cases, some parts still won't work on a V8 so you still have to replace stuff.
I never though it made much sense to have two different versions of the same transmission but this is GM, alot of stuff they do doesn't make sense
It's not a matter of swapping bellhousings like the T-5.
someone may be able to chime in with more info on the subject, good luck with the build.
Last edited by 88KARRV6; Nov 1, 2006 at 10:22 PM. Reason: clarify, and to add info
Old Nov 2, 2006 | 06:46 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
there is more than 2 versions of the 700. you can get a v-8 700 and have it rebuilt with upgaded parts. your stock v-6 parts arent going to last anyway. the stock 700 v-8 parts wont last to any abuse either. i would say that if you plan to go higher in HP then you should convert to th350 now before you waste money on the 700. i can get a 350 built by a local perf shop with the tq for 1000-1200. a comparable 700 would be close to 1800-2000. if you just plan to keep the hp reasonable and not beat on it the 700 will get you some mpg.
Old Nov 2, 2006 | 08:36 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
thanks for the input guys. I'll just trade my rebuilt v6 700 or a rebuilt v8 700... i have a buddy that rebuilds these transmissions a lot and has some extra's lyin around.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
