v6-v8 swap ENGINE IS IN NEED HELP FAST
Old Nov 5, 2006 | 07:19 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
I have a 91 camaro Rs that had a v6 engine in it
i got a 350 tpi tranny wiring harness and cpu from a 87 gta
have it in the car everything bolted down and what not... everything lined up.. now im guessin i have wiring issue....
the moment of truth came.. i put the key in.. turn.. and nothin.. not even a turn over..
The fuel pump did not turn on.. the engine turns over with a push button(just to see if starter works.. and it does!) fuel pump i know works i just drove it the other day and its not even a year old.
i have the chip in my key as most of you probably do.. does that have to do with the old cpu? or that doesnt matter??
uumm any help would be great... what differs??? wiring harness not right?? anything!!!!! im so close
oh and the engine ran sweet when it was in the gta so i know it ran!! i helped the guy pull it and everything..
has to be something stupid or easy or wiring... i hope
anything would be great!!
Old Nov 5, 2006 | 07:56 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
Well when i did my swap i had alot of problems with my wiring harness. The v6 harness has their pins located in different spots etc. The only way your going to find out what goes where is compare two diagrams which i had to do which deff was not easy... You can compare the wiring color on the old harness where the block goes (drivers side) and just match the colors up by taking the pins out and moving them so they match up. That will be one of many things that i had a problem with.
Old Nov 5, 2006 | 08:01 PM
tourville's Avatar
Car: 1991 Camaro RS
any ideas where i can get the harness from?
Old Nov 5, 2006 | 08:08 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
As far as i know they do not make a harness from swaping from a v6 to a v8 for a thirdgen camaro or firebird. I could be wrong... You need to back-track with wiring diagrams alldata etc and figure out where the starter wires go etc. The v6 to v8 swap is pretty straight forward but wiring is the hard part. I think their are some wiring diagrams on this site somewhere. The diagram your looking for would be the starter ciruit....
Old Nov 5, 2006 | 08:19 PM
tourville's Avatar
Car: 1991 Camaro RS
lol sorry didnt mean to say get the harness ment where can i get the two diagrams from! sry very tired
Old Nov 5, 2006 | 08:28 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
I know advance auto zone etc carries books on spacific cars called haynes manual i belive. These are for 1986 cars anyway they might be the same as far as the 1987 f body harness goes. 1986 F-BODY WIRING
Old Nov 5, 2006 | 09:07 PM
tourville's Avatar
Car: 1991 Camaro RS
what is all this vin h 2 s f stuff???
Old Nov 6, 2006 | 07:56 PM
tourville's Avatar
Car: 1991 Camaro RS
just in case anyone ever searches for this... the following website has wiring diagrams from 1982-1992 of each engine and body!!! AustinThirdGen.Org » Content » Tech Articles » 3rd-gen wiring diagrams very good website only thing it does not have is the bulkhead connector diagrams i was able to find them by searching the forums and krisb410 was able to fax me the 91 bulkhead diagram!!! very big props to him thanks a lot!!
thanks everyone for looking and hope these things help you out also
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
