86 305 tpi to 91 350 tpi starting prob!!
Old Nov 5, 2006 | 11:32 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
engine crank but does not start
What we did....
first we had an 86 tpi car with an hei dist. and MAF we take everything out
I had a 91 z28 donor car for the swap so i deside to take everything, easier said then done, its a MAP engine with coil away from the dist.
we change underhood harness, now underdash harness, took the cluster and sterring, ecm
now probleme not able to find the fuel pump wire in the kick panel, we are able to start the pump when jmping it directy on the connecter under the car. So it should atleast run for 2-3sec.
The car was runing great when it was in the 91
this car is starting to make me sick....and its not even mine
Thanks for the help sorry if there is missing some info im missing some sleeping this past month since im working near 100hrs a week because of this car
Seb
84z96L31vortec
Aug 20, 2017 12:16 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
