350 5spd question
350 5spd question
My question is this: can I use the tranny bellhousing from a 305 5 spd on a 350 that I am connecting to a 5 spd? And just out of curiosity does anyone know why gm never made the 5 spd available with a 350? Thanks
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Yes, you can use the same bellhousing.
And they didnt come in 350's i think because they are not rated for the torque the 350 TPI makes.
Transmission: 4L80E/4L80E
There are 3 common theories as to why the factory never offered a 5-speed behind a 350 in 3rd gens:
1. The T5 wasn't strong enough to handle the torque of a 350 (the way the factory rates a transmission is to subject it to the rated torque & RPMs for 24 hours straight - shock loads don't come into the equation).
2. The 350 wouldn't meet emissions requirements with a T5 behind it.
3. A 350 with a T5 in an f-body was quicker than the Vettes of that time.
Personally, I don't buy #2 at all.
#1 has some credibility, but 'Stangs had a different T5 that is plenty strong.
I think #3 is the real reason. . .
No high-RPM clutch dumps, no speed shifting, and it will last a long, long time.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My T5 broke the 3-4 shift linkage twice running 13 second ET's (simple fix). But it shattered the 3rd gear and input shaft running 12's. I then replaced it with a T56.
NinjaNife
Aug 23, 2015 11:49 AM
