My V8 to V6 conversion
Old Jan 3, 2007 | 09:38 PM
power6's Avatar
Car: 87 Turbo Regal
Engine: 3.8 SFI turbo
Transmission: 200 4R
slowly but surely coming along...
Attached Thumbnails My V8 to V6 conversion-misc-004.jpg   My V8 to V6 conversion-misc-011.jpg   My V8 to V6 conversion-misc-006.jpg
Old Jan 3, 2007 | 09:49 PM
power6's Avatar
Car: 87 Turbo Regal
here's a shot of my mufflex exhaust and 3" downpipe for comparison. Next is the the front mount intercooler. I moved the plastic airdam forward using fabricated brackets, so it fits under the intercooler rather than behind it.
This project has been a little bit more involved than I wanted. But, I can't really complain as everything thus far has come together fairly easily. I've got an issue with fuel lines, but I think I should be able to find some fittings if I hunt hard enough, and make my own lines from the chassis to the rail, and back. The wiring "should" come together as I'm using a custom dash harness from Casper's electronics. She oughta go mid 10s without even breaking a sweat. Any faster, and I'll need to address the old 9 bolt posi out back. Hope ya'll like it!
Attached Thumbnails My V8 to V6 conversion-misc-001.jpg   My V8 to V6 conversion-misc-008.jpg
Old Jan 3, 2007 | 10:01 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
that is amazing and the bird looks clean.
Old Jan 3, 2007 | 11:22 PM
firstfirebird's Avatar
Nice work! Seeing that you had a V8 before, I'm guessing your using a gen I 3.8 and using your (90 degree) stock tranny? I'm adopting the Buick GN set-up to my 3.1, and v-mounting my intercooler betweeen the radiator and serpintine belt. Although I'll probably use an electric fan rather than one mounted to the water pump or crank.
If you click on my signature or garage you can check out my science project...
Old Jan 3, 2007 | 11:32 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
sweet keep us updated on the project
Old Jan 4, 2007 | 07:44 AM
tarakian's Avatar
Car: 1992 - RS - T-tops
Engine: 3.1
Would you have any specifics on your set up?
Old Jan 4, 2007 | 06:02 PM
power6's Avatar
Car: 87 Turbo Regal
87 Buick Grand National 3.8 liter bored .020 girdled and steel caps
Forged JE pistons
stock shot-peened rods
62 lb./hr injectors
high volume intank Walbro fuel pump
Accufab afpr
custom ductile iron roller camshaft - Comp Cams
1.60 ratio roller lifters
chromolly pushrods
Big valves, springs, titanium locks and retainers
ported/polished heads
ARP fasteners throughout
port matched stock intake
precision high volume upper plenum
70 mm throttle body
Precision TE-45a large shaft turbocharger
Tial 38mm external wastegate
stock - remapped ECM (Turbo Tweak)
stock crank
big front mount 4" core 3" pipes
Precision Industries 10" multi disk lockup torque converter
Fully built 200 4R tranny
big exhaust
tons and tons of suspension goodies
4th gen TA leather interior
lots of other stuff I'm sure I forgot...
I bought the car here off the board back in the spring of 2005. I went through my old emails, but can't find any of the ones pertaining to the purchase. I thought the previous owner might be interested in the transformation. He was a great guy from Jersey. I flew from Knoxville, TN and drove the car back in one day - 11 hrs back. I've owned Buicks and 3rd gens for years. Now I have the best of both.
Old Jan 4, 2007 | 10:26 PM
tarakian's Avatar
Engine: 3.1
Thats a nice set up whats the power that thing puts out
Old Jan 5, 2007 | 09:40 PM
power6's Avatar
Car: 87 Turbo Regal
should make 450 hp on pump gas at the wheels, and close to 600 on race fuel with lots of boost and timing. I've personally seen these Buick motors make over 400 horses with a turbo and injectors alone - stock unopend motors! Believe it or not, even more impressive than the hp is the torque of the Buick V6s. It should put down some ridiculous numbers - probably 600 to 700 range. The combo in my car is identical to a friend's 86 T-type here in town. He can't keep the rear end under it at any speeds slower than 60 mph. I can't wait to get her back on the road.
Old Jan 6, 2007 | 08:45 AM
I love the fact that your going to a V6 (although I'm slightly partial). And yes the buick motors are monsters, my friend has an 87GN with 9300miles on it, it even smells like a new car still (actually how new cars smelled in the 80's, can you say polyester LOL). It even has the fact. tires on it that have probably been siliconed one too many times.
Studying his car made me decide to adopt the v-mount intercooler so I didn't have to relocate batt/charcoal etc. Not to mention we have a ton of room in front of the 6er.
Old Jan 6, 2007 | 09:41 PM
power6's Avatar
Car: 87 Turbo Regal
I've owned an 86 Z28, and a 91 Formula years ago. Then I got into Buicks, and I've had 3 T-types, and loved them, just missed the handling and braking of the F-body. I know the TTA is the most logical alternative, but I just wanted something a little different, and a car I could run hard and not feel bad about it. I'll keep you all updated as to the progress. Should have her running shortly.
Old Jan 27, 2007 | 01:07 AM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Hey power6, are those GN Manifolds? I was wondering if they would fit in the 3d gen. I hear you gotta get rid of the AC system to use the GN heads, is all this your case? Also, what pulley setup are you using on the engine? GN style? Im looking into a swap that would involve no major cutting of my car!! Oh well, let me know what you got. Thanks!!
Old Jan 28, 2007 | 12:31 PM
power6's Avatar
Car: 87 Turbo Regal
Yep, GN heads and exhaust manifolds. I removed the AC and installed a 1LE heater box, which frees up a bunch of room. I think you can retain your AC with the GN heads and headers, but it makes the downpipe clearance an issue. Also makes changing the back spark plug very difficult. If you want to make sure your stuff fits with AC, just go with TTA heads and headers. It will just take some searching, as the TTA headers are out of production, and you'll have to find a used set. The heads are plentiful, as they are the same as the 3.0 liter front drive motors.
So far, I haven't cut anything other than some small holes in the front crash bar for increased air flow to the intercooler. My biggest problem is the wiring. I've got a "plug and play" harness from Caspers, but wiring is not my strong suit. I'll need some fabricating done to my downpipe, and a new driveshaft made. The fuel lines are giving me fits too. I am trying to retain the stock hard lines on the F-body, and jump over to the rail and regulator with braided line, but no one in town wants to mess with factory style O-ring fittings. Other than that, it is pretty much done. I've gotten to the point now where the stuff left is all stuff I don't know how to do, or never done before. So I feel like I'm getting bogged down, and not making any progress.
Old Feb 27, 2007 | 02:24 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Wow. Your swap is pretty much verbatim to mine except I went with the 700r4 w/ 3500 stall (CK Performance custom tc), 212/212 roller cam w/ T&D Rockers, 72lb injectors, ported/polished gn heads, and a Dana 60 w/ 3.54's. You will have to let me know how that works for you. I went with the alkycontrol kit also.
Have you ran the car yet? I should have mine running again in a couple weeks and on the dyno for tuning.
Old Mar 3, 2007 | 10:15 AM
power6's Avatar
Car: 87 Turbo Regal
Not running yet. If I were on schedule, it would have been running last month. I ran into a snaffoo with the fuel lines. Got that worked out now. Unfortunately, I am having some problems with my engine wiring harness. Turns out, the old factory harness out of the 87 GN isn't in as good of shape as I'd hoped. Its been hacked on pretty severly, and is going to be more work that it is worth to correct it. Looks like my budget is completely shot, as I'll need to get a Casper's full engine harness. I'd rather spend the money and know it is going to be right than spend who knows how long trying to fix the one I've got, not knowing if it will work.
I need a drive shaft, and some welding/fabricating on the down pipe and rest of the exhaust, plus finishing the wiring. I need a shifter and cable for the 200 4R, since the factory Firebird 700R4 shifter cable won't bolt up. I'm sure there are other things I'm forgetting, hopefully they will be small things. Now that the weather is getting nice, I am dying to get her on the road.
Old Mar 5, 2007 | 08:41 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, I have someone trying to figure out how to get the 89 TTA wiring harness to work with a 91 stock gauge cluster. He got it to work with a 92 camaro gauge cluster so it should work. After that I just need a good tune and some DR's and than I got to get my *** to the track to practice launching.
Good luck with the rest of your swap...this sort of engine swap is not as easy as it sounds and definitely not as cheap.
Old Mar 18, 2007 | 09:09 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Power 6????
91 Bird305????
How's the wiring coming? I am waiting with baited breath to see how it turns out...
Old Mar 21, 2007 | 03:25 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Re: My V8 to V6 conversion
Should be ready around Saturday or Monday. I will post video / pictures when it is finished. I plan on hitting the drag strip on April 7th if everything is a go.
Old Mar 31, 2007 | 04:25 PM
BLACK92B4C's Avatar
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
I have a 1989 2.8 Firebird right now, I just stumbled across a complete drivetrain out of a 1987 Grand National. Looking at my setup it might be a little easier since the fuel lines are all on the same side. Can one of you all sort of give me a run down on what is required for the swap? I'm trying to decide if this is a good idea or if I should just keep driving the car lol!
Thanks in advance, your project looks great. I'm following it on turbobuick too!
Old Apr 7, 2007 | 11:05 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
Wow, that's a real nice looking 'bird. I've been toying with the idea of swapping the GNX drivetrain into my '90 RS 305.
Old Apr 10, 2007 | 12:46 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Why just the drivetrain?
Old Apr 13, 2007 | 02:13 PM
chikn305's Avatar
Very nice ride power6. Ive always been a big fan of the 91-92 Formulas. I have an 87 with a TTA motor in it. Its definitely alot more fun than the tpi. The long block is stock with a ta-62 and 65lb injectors. The car has went 11.4's with a 1.6 60ft. I am in the process of putting on Champion irons, champion intake, and custom roller cam.
Old Apr 13, 2007 | 03:22 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Wow!
That Formula is just awesome...
Great car!!!!!!
Old Apr 24, 2007 | 08:37 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Nice swap cikn305! How do you like those tires in the rear? What kind of suspension work do you have done?
Old Apr 25, 2007 | 07:26 AM
chikn305's Avatar
Thanks guys. The tires are freat they hook really well. This is my second set I had them when I had the nitrous small block too. The only suspension stuff I have are lca relocation brackets, 1-1/2 drop springs, and I made a mount that bolts the torque arm to the crossmember.
Old Apr 25, 2007 | 08:46 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Cool, thanks.
Old Jun 13, 2007 | 10:02 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Any status updates?? I am tying up loose ends on mine as well. I think I found the fuel fittings to connect to the body rail. What did you do/use? I am getting anxious as well to get mine rolling. I got a bunch of little stuff to do and am running out of money.
I cant seem to get my headlights working again, but I havent hooked up C207(Firebird) to C437(GN Harness) I also have a couple loose wires from C100. All I get is that "you left your key in ignition" buzz I gotta do some tranny stuff(mod shifter linkage) to fit a TH400, Trans Cooler & Temp Gauge, I got my DS being made. I think it is approx $130 for all the fuel fittings. I'll make a post w/ my progress.
Old Jun 14, 2007 | 05:01 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Yes!
Definitely keep us posted! I am getting anxious to do my Buick V6 swap as well. I have to get my garage first, though!!
Old Jun 24, 2007 | 10:17 AM
power6's Avatar
Car: 87 Turbo Regal
I've been slacking bigtime on the project. Wife and I had a baby in May, and I also bought this:
I'm getting geared back up to finish the Formula. I only lack some exhaust fabricating, a drive shaft and shifter. Bought a complete custom wiring harness from Casper's electronics - expensive but should be a huge time savings. My fuel fittings are done, just need to get the lines made. I bought a new 70mm throttle body and precision upper plenum too. Sorry to take so long...
Old Jun 26, 2007 | 02:22 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Just don't forget the pictures!!!
We all want to see the finished product so that we will also know what ours will look like afterward!!
Old Jun 26, 2007 | 08:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
earl's makes the adapter fittings for your O-ringed factory fuel lines to convert to -6AN lines. FYI.
Old Jul 11, 2007 | 12:19 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well mine is done (or was done) for about a week and then my oil pump went. SO I have to replace that now. But it seems to move pretty good. Once the oil pump is replaced, I will get it on the dyno and the track and post some numbers. Here are some pictures so far though.
Motor
Interior (yes, I am putting my computer back)
Old Jul 11, 2007 | 09:09 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
oil pump gone?
Did you pull the oil filter adapter cover and prime it with vaseline? That's how you prime it!
Old Jul 12, 2007 | 08:08 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
No I did not and didn't know that is how you prime an oil pump. I just figured a few turn overs on the motor and then I could start it.
Old Jul 12, 2007 | 05:33 PM
chikn305's Avatar
91bird sorry to hear about the oil pump. Its good to see some of these projects finally getting on the street. Im currently replacing the rear in mine. I broke my mini spool in the 7.5 so now Im going to out a 8.5 in out of a GN in it.
Old Jul 12, 2007 | 10:51 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
You should still try to prime the pump before you do anything else; it can't hurt.
You can disconnect the fuel or ignition to keep it from running and just crank it until you have oil pressure (after priming the pump)... then run it.
Even if you have to replace the pump, the kit is cheap and it's easy to do; JUST DON'T FORGET THE VASELINE THIS TIME!!!!!!
Old Jul 14, 2007 | 10:49 AM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
I just finished my 3.8L Firebird last weekend, got it totally broken in now. This thing pulls harder than my LS1 Formula, and it is only boosting 13lbs at the moment. I havent started to tune it yet whatsoever.
Old Oct 19, 2007 | 08:58 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I am breaking mine in right now. Just got it up and running.
My 1991 Pontiac Firebird w/ an 87 Grand National motor starting up.
Old Oct 19, 2007 | 10:16 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Oil pressure is good????
Old Oct 19, 2007 | 10:26 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yup. Working great. Just gotta put some miles on it now. I will probably post more videos soon with me getting into the boost.
Old Oct 19, 2007 | 11:19 AM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Congrats to getting it all ironed out. Get that beast on the streets and get some timeslips!!! I did a best of 12.20@112.14 mph in mine last weekend. Backed it up with a 12.29 also! Its alot of fun sneaking up on people without the V8 Sound!! Good luck!
Old Oct 19, 2007 | 08:23 PM
  #42
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
More conversions around here than I thought, nice work
Old Oct 20, 2007 | 12:21 AM
  #43
Nice work! Can't wait to see numbers.
Old Nov 10, 2007 | 12:58 PM
  #44
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
question for ya! I'm having the same troubles with the fuel lines with my swap, What did you end up doing to get everything connected? What size of braided lines did you use ...I'm running 8AN. And did you upgrade your fuel pump?
thanks and good luck with the project!
Old Nov 10, 2007 | 07:22 PM
  #45
KrisW's Avatar
Engine: 2.8/TBI/TPI
Are you running the Buick ECM? The Buick specs (and turbo T/A) require a higher pressure pump. It really depends on what ECM/injector combo you are running. If you are running the pump from a 2.8 (as your profile suggests) then that is inadequate for flow and pressure. You can still get the proper pump for a Turbo Trans Am from the auto parts store, it's the same one used in later Vortec V8 trucks. It's only about 5 bucks more than the stock replacement for your V6.
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
