Corvette L98 and 700R4 swap questions
Old Jan 10, 2007 | 02:16 AM
res1bxh3's Avatar
I know the difference between the engine is the heads and egr but i would like to know what would need to be done to put an L98 and 700R4 from a 89 corvette into a 89 camaro? would it bee any different than a L98 and 700R4 combo from a camaro?
Old Jan 10, 2007 | 10:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Vette TH700 will not have the torque arm mount provision on the tailshaft housing. You should be able to swap over your 3rd gen housing to the Vette tranny.
I have also heard that the Vette oil pan and pump pickup are different than 3rd gen, but I don't know that from personal experience. Again, swap over 3rd gen parts (assuming you have a V8 now - if not, you're going to have to find those parts).
Old Jan 10, 2007 | 04:52 PM
res1bxh3's Avatar
thanks the reason im asking is because im going to purchase this item http://cgi.ebay.com/ebaymotors/1989-...QQcmdZViewItem and i was hoping it would go in with not to much hassle. so it is infact a th700 not a 700r4?? ive never even heard of a th700?? ohhh and i do curently have a blown l98 in it right now, should i go foward with this or should i look for an engine from a fbody also with what you said how hard would it be to change the tranny housing?
Old Jan 10, 2007 | 11:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The engine oil pan and oil pump pickup from the Corvette won't work. You'll need the correct F-body parts. You'll need Camaro exhaust manifolds as well, the Corvette peices will not work. Otherwise, you're golden
Old Jan 10, 2007 | 11:53 PM
five7kid's Avatar
"TH700" is an abbreviation for "TH700R-4", the proper designation for the transmission.
If you can handle the price of the Vette piece, go for it. Be sure to clean the f-body pan thoroughly before installing it on the Vette engine. A new oil pump would be a good idea while you're at it.
Remove 4 bolts, slide the housing off each tranny, slide the f-body housing onto the Vette tranny, install and tighten 4 bolts.
Old Jan 11, 2007 | 12:55 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sounds like an easy swap, but if you don't already have them, you should look into some hedders while you're at it! 2055s.
Old Jan 25, 2007 | 02:51 AM
res1bxh3's Avatar
five7kid by the tranny housing do u mean that little extension piece at the end of the tranny???
Old Feb 7, 2007 | 04:24 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Anyone know the specs on the alum. L98 heads found on the vette. I'm looking for the size of the combustion chamber (in cc) and the intake & exhaust size (in cc). Thanks
Old Feb 7, 2007 | 12:24 PM
Air_Adam's Avatar
58cc chambers, 165-ish CC intake runners, 60-ish CC exhaust.
Old Feb 7, 2007 | 02:01 PM
five7kid's Avatar
Sorry, dropped the ball there.
Yes.
Old Feb 7, 2007 | 02:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally Posted by five7kid
"Remove 4 bolts, slide the housing off each tranny, slide the f-body housing onto the Vette tranny, install and tighten 4 bolts.
Uh.....no!
The output shaft is also shorter, so changing the tail housing is not going to work.
Old Feb 7, 2007 | 03:10 PM
res1bxh3's Avatar
what else need to be done to compensate for the shorter shaft
Old Feb 7, 2007 | 03:17 PM
five7kid's Avatar
Originally Posted by Dyno Don
Uh.....no!
My direct exposure to Vettes is admittedly limited. I wasn't aware that there were different TH700R-4 2WD lengths. Haven't seen that documented anywhere else.
If that's the case, the output shaft is the first thing that goes in from the front of the case.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
