305 to 350
Old Jan 14, 2007 | 02:36 PM
toms86Z28's Avatar
305 to 350
in about 4 weeks im putting a 350 into my 86 camaro z28 tpi. im going to swap the cam in it. but my problem is i have no idea what size injector's to use.
Old Jan 14, 2007 | 07:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
22 pound.
Old Jan 14, 2007 | 11:09 PM
toms86Z28's Avatar
what would happen if i used the 24lb? because my friend has a supercharger i might get off him. and the computer in my 86 for the 305 can it be used for the 350 if i get the 350 prom
Old Jan 15, 2007 | 12:05 AM
five7kid's Avatar
No problem for 24 lb. No problem for the ECM w/350 PROM, but I'm not sure MAF can handle the supercharger.
Old Jan 15, 2007 | 08:02 PM
toms86Z28's Avatar
ok for the fuel injectors should i use http://store.summitracing.com/partdetail.asp?autofilter=1∂=VNM%2DHP%2D624%2D8&N=700+115&autoview=sku these if i can or
http://store.summitracing.com/partdetail.asp?autofilter=1∂=ACC%2D150824&N=700+4294908216+4294908198+4294840140+4294889107+4294925008+115&autoview=sku
i would think accel would be better
Old Jan 15, 2007 | 10:31 PM
five7kid's Avatar
You might want to search, but I recall hearing in the past not-so-good things about Accel injectors.
Old Jan 15, 2007 | 10:54 PM
toms86Z28's Avatar
what do you suggest? and do you know of anybody that has a set of good used 22lb. injectors for sale. i can't do my cam swap untill my trans is in and broken in. i dont want to destroy a new tranny trying to get a motor running right. what would happen if i run the 24's on the stock 350
Old Jan 16, 2007 | 12:52 PM
five7kid's Avatar
Check the classifieds on this Board for somebody selling 22 lb.
But, the 24 lb injectors shouldn't cause any problems.
Old Jan 16, 2007 | 11:03 PM
toms86Z28's Avatar
im just gunna wait to get the 24lbs. till the summer when i do the cam, heads and what ever else. i'll just find the stock 22lbs. for now
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
