305 carbed to 350 tpi
Old Jan 14, 2007 | 08:07 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
Well I posted this same question on thirdgenusa.com, but I thought I would post it hear also. I was just wondering how hard it would be to replace my 305 carbed engine for a 350 tpi. Keeping in mind the owner b4 me rip the computer system off of the car, and left a mass of wires everywhere. Also how much would this swap cost? I’m sure ill have more questions later, but for now that’s I have….thx in advance guys…
Old Jan 14, 2007 | 08:20 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
It's easier to put another carbed engine in if you don't have the harness or fuel system for it , the cost would be right up there if you have to buy everything seperatly or even if you sourced a donor car to take the drivetrain out of complete with the fuel and wireing ...plus the fact the TPI is just not that good of a system in stock form you would be looking at $2500.00 worth of upgrades to get a TPI to make decent power and for that same amount you can build a carbed engine that will run circles around a TPI.. all smallblock engines are tha same fit wise so you aren't limited to just 305-350s 400 sbc and even big blocks will bolt to stock mounts and transmissions (auto) if you have a stick trans you will want to change it out for an auto if you go larger than a 305, as the T-5s won't hold over 300fpt with any reliability.. the choice is yours but if your car is carbed now it will be alot cheeper if you stick with a carb..
Jake_92RS
Jan 28, 2020 10:37 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
