350 swap same tranny
Old Jan 23, 2007 | 07:17 PM
hate101's Avatar
i have a v6 rs now and my engine is old and shes beat up, i wanna put a 350 in there, can i use the same transmition i have for the 6 or do i have to get a new one
Old Jan 24, 2007 | 12:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming it's an automatic, no.
If it's manual, only with a V8 bellhousing, and a clutch disk that fits the small spline (read: weak) input shaft.
Old Jan 24, 2007 | 02:11 AM
Alpha 1 [BAI]'s Avatar
Car: 89' rs
Engine: the akward silence causing 2.8
Transmission: 5 speed or lack thereof
i was looking to do the same and have just installed a new stage two clutch
will that work with the 350?
thanks
Old Jan 24, 2007 | 12:34 PM
five7kid's Avatar
The V6 and V8 disk and pressure plates are not the same size. From what I understand, you cannot mount a V6 pressure plate on a V8 flywheel. You can use the smaller V6 disk with the larger V8 pressure plate, but it's not ideal.
More has been discussed on this topic on the Transmission forum, but I understand an S10 disk with the same number of splines as the f-body V6 tranny but with a larger diameter disk is available to make it a little better.
But, the V6 T5 is inherently weak, so considering using it behind a V8 is a recipe for breakage.
Old Jan 25, 2007 | 01:49 AM
Car: 89' rs
yeah i read the other threads relating to this and after trying to decifer an answer from the argueing i figured ill bite the bullet and go with 350 trans
thanks for the summary though
camaro11j
Sep 19, 2018 08:49 AM
bellez77
Sep 5, 2015 08:39 PM
crazynights
Aug 21, 2015 06:53 AM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
