Will my crossmember work?
Old Feb 27, 2007 | 01:22 AM
MotorCityRS's Avatar
Car: 90' Camaro RS
Engine: 3.1
Transmission: 4l60
I'm doin a non-emissions v-6 to v-8 swap. Will my 2004r crossmember work with a 7004r? I got someone to trade me for my th-350. And it's kinda an obvious answer but can I use the same driveshaft?
Old Feb 27, 2007 | 01:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let's understand exactly which transmission you have. If it is a stock 1990 model 4-speed auto, it's a TH700R-4, which is mounted the same and uses the same driveshaft as the V8 TH700R-4.
Old Feb 28, 2007 | 12:42 AM
Car: 90' Camaro RS
Engine: 3.1
Transmission: 4l60
I'm gonna have to check my title again on the year. I'm almost positive it's a 90', but it could be a 91. It's one of those years and the fact is it has the new interior. That's how I know. Airbag and all. Is there a differance in the two year rs's? Did both have 700's?
Old Feb 28, 2007 | 06:36 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Both had 700R4, V6 and V8 models.
Old Feb 28, 2007 | 03:06 PM
five7kid's Avatar
So, you won't need a different crossmember or driveshaft, but you will need a different transmission. The V6 and V8 transmissions are the same length and the like, but the bellhousing pattern is different.
Old Mar 3, 2007 | 10:11 PM
Car: 90' Camaro RS
Engine: 3.1
Transmission: 4l60
Sweet! thanx a ton guys. Thank God for forums like this. Without you guys this would be hard! LOL
Old Mar 5, 2007 | 05:02 PM
five7kid's Avatar
Tell me about it. Swap date, Jul '99. Join date, Mar '00.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Elliswon
Aug 10, 2015 12:33 PM
