engine swap help
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
th v8s are the same but can you tell me if and what bellhousing will fit on a v6 5 speed that will bolt to a v8
Transmission: 4L80E/4L80E
The V6 5-speed will bolt to a V8 bellhousing, but that's about where the good news ends.
i was hoping to be able to use the 5 speed because i really dont want an automatic and dont have the extra funds to buy another tranny
You'll need a V8 flywheel, bellhousing and pressure plate. Get an S10 V6 clutch disk, should have the same spline size as the V6 input shaft. Try a search, it's been discussed.
You could use a V6 disk, but it would be very small. And, you'd have to use a V8 pressure plate because of the flywheel.
Make sure you put a pilot bearing in the V8 crankshaft, or your V6 transmission won't be long for this world. As it is, you'll have to really baby the V6 tranny with a V8 in front of it.
theshackle
Mar 5, 2017 06:37 PM
