305 TBI to 355 Carb swap questions
Old Mar 26, 2007 | 10:35 PM
griff305's Avatar
I am swapping my 305 TBi on my 92 RS for a 355 that is getting bored .010 over. I stripped all the engine bay wiring except for the lights. Can I re-wire into my stock guages? Will I be able to use the electric fuel pump or will it be easier just to use the mechanical one?
Old Mar 29, 2007 | 01:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 305 TBI to 355 Carb swap questions
Yes, your stock gauges should work fine with the new motor.
Easier to use the mech pump.
See my more explicit post on the exact same thread here;
https://www.thirdgen.org/forums/engi...ind-305-a.html
Old Mar 30, 2007 | 08:58 PM
griff305's Avatar
Thanx but I am actually buyin an 82 Z28 no motor or trans. So i wont have to worry about the gas lines or any of the electrical.
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
92purpz28
Aug 11, 2015 02:30 PM
tero
Aug 6, 2015 06:34 PM
