pulling motor need help
Old Mar 31, 2007 | 09:49 PM
redrocket87's Avatar
hey guys i just started disconnecting everything to swap out my 2.8, auto to an LT1 auto, my question is, Do i pull the motor and tranny together or seperate? and can i do this easily without taking the front clip off? thank you.
Old Apr 1, 2007 | 02:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: pulling motor need help
its simpler to remove them together. with a good engine hoist you can get it all out without taking off the front clip.
Old Apr 2, 2007 | 01:43 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
A load leveler would be helpful too.
Old Apr 2, 2007 | 02:01 AM
89TtopCustom's Avatar
Car: 1989 Firebird Formula
Engine: Blown LB9(thanks steve)building 383
Axle/Gears: Borg Warner 9-bolt 3.70
i pulled a 305 with t-5 connected to it using a 10 ft. vertical A-frame lift with a 2 ton chain-fall. only had to remove the radiator and a/c condenser. A friend/helper is VERY helpful in the process no matter what.
Save yourself the time and effort pull the useless engine and tranny out all at once!
Old Apr 2, 2007 | 04:38 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
definately pull the engine/tranny together. its a big pain in the *** to remove the tranny if you dont have a lift to put the car on.
Old Apr 8, 2007 | 08:18 PM
snowballinaz's Avatar
Car: 1988 Camaro
Engine: 305 TBI
I am also getting ready to pull my engine out and give it a once over. Have never done this before but ready for the experience. Hope its not too much of a headache.
Old Apr 8, 2007 | 09:05 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
I did mine together without issue. I was by no means experienced and it was really quite easy.
Old Apr 9, 2007 | 03:54 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
Like everyone else said take them both out together. A good hoist plus someone to help you will make the process much quicker and easier.
Old Apr 11, 2007 | 11:22 PM
JTB91RS's Avatar
Car: '91 Camaro RS
Engine: Carbed 350
Definitely pull them together. I would HIGHLY recommend having a friend help because a lot of things will bind up on the way out. You will also want the front of the car to be jacked up (need it anyways to disconnect everything under the car), otherwise the tailshaft of the trans will hit the ground and prevent the engine from "tilting" out as you lift. You shouldn't have to remove anything off of the front of the engine since the V6 is short.
Steve78LT
Feb 24, 2016 12:15 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
