2.8 swap to a 350 motor and tranny
Old Apr 25, 2007 | 11:24 PM
hedshed38x's Avatar
Ive got an 86 camaro with a 2.8 , manual transmission and im trying to swap it with a 350 and a th350 tranny. But im having problems converting the manual to the automatic. tranny mount? drive line? Im just plan lost can anyone steer me in the right direction?
Old Apr 25, 2007 | 11:42 PM
rob_roy03's Avatar
Re: 2.8 swap to a 350 motor and tranny
the things you will need, 1-new motor mount for the frame. 2-you will have to run new fuel line. the 2.8 fuel pump is on the opposite side of the motor than a 350. 3-bigger radiator. and thats it. the tranny crossmember will work the same, but the tranny for the 2.8 is different than the one for the 350. I had to do all this my self not to long ago. good luck
Old Apr 26, 2007 | 06:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The TH350 won't have provisions for mounting the differential torque arm. You'll need a kit that provides that mounting. Available from Summit and Jegs.
You'll have to move the tranny crossmember up because the TH350 is shorter than the T5 you're taking out. This requires a longer crossmember.
Old Apr 26, 2007 | 07:25 PM
hedshed38x's Avatar
I went to pu t on the new mounts to the frame but the holes dont line up, do i need to drill new ones?
Old Apr 26, 2007 | 08:26 PM
five7kid's Avatar
Engine mounts on the front crossmember? They should line up without drilling holes. You do need to move the brake line to the back of the crossmember so the mounts don't sit on top of it.
Did you read the V6 to V8 sticky at the top of this forum?
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
