just put on new heads
Old May 20, 2007 | 04:50 PM
thrilla135's Avatar
Car: 1987 trans am
Engine: 406
Transmission: th:400
Axle/Gears: 4:88
i just put on a brand new set of world products sportsmen 2 heads....and they smoke pretty bad when i start it up....i think that has somethign to do with me not adjusting the valves correctly......would that mean i made em too tight or too lose?
Old May 20, 2007 | 10:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It probably means there's something wrong with the valve seals.
Old May 21, 2007 | 12:20 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Re: just put on new heads
It doesnt really sound like a valve issue. Like he said, sounds like valve stem seals.
Did you get the heads assembled or bare? If you got them assembled I'd be called tech and raising hell. If you assembled them yourself then you probly didnt get the seals on right.
Before you do anything, I'd pull the valve cover and pull each rocker off and check those seals.
Jake_92RS
Jan 28, 2020 10:37 PM
CRFred
Feb 7, 2016 11:39 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
anesthes
Aug 8, 2015 09:37 PM
