freeze plugs
Old Jun 5, 2007 | 06:34 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
freeze plugs
im building a 350 and i am going to put the freeze plugs in today and i was wondering the best way to do this properly.
Old Jun 5, 2007 | 07:03 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: freeze plugs
IMHO if you have never done it let some one who has done it befor do it. But if you or dead set on doing it the way I did mine is to get a flat faced hammer (body hammer) and put some sealer around the plugs and tap them into place or if you don't have the hammer use a big socket.
Old Jun 5, 2007 | 07:07 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
Re: freeze plugs
how necessary is the sealer and where can i get some?
Old Jun 5, 2007 | 08:07 PM
Car: 1992 camaro
Axle/Gears: 3:73
Re: freeze plugs
Go to AZ or Advance or napa ................. Get the one in the brown bottle with the Indian on it thats what I used havent had a problem so far. I dont know the real name of it sry.
Old Jun 5, 2007 | 09:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: freeze plugs
"Indian Head Shellac" is what you're thinking of. If the block isn't corroded, you don't need any sort of sealer, but it certainly won't hurt anything.
Use a socket just slightly smaller than the inside diameter of the plug and drive it in with a hammer, being sure to make sure you're putting it in straight. It's hardly rocket science, even if you've never done it before.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
