Has anyone used this cam?
Old Jun 26, 2007 | 06:58 PM
1badnhra's Avatar
Car: 86 Firebird
Engine: 355 vortec heads
Transmission: 700r4 Huges 2500 stall
Axle/Gears: 4:10
I was just wondering if anyone had used this cam. For those who have, do you like it? How does it idle? I'll be using a 700r4 and a 2500 stall. Is it streetable?http://www.cranecams.com/index.php?s...81&lvl=2&prt=5
Old Jun 27, 2007 | 06:25 AM
ljnowell's Avatar
Re: Has anyone used this cam?
thats a pretty basic cam grind, there a lot more out there that are better. Look at the comp cams XE cams or the "smaller" voo doo cams by lunati.
Old Sep 9, 2007 | 10:24 PM
1badnhra's Avatar
Car: 86 Firebird
Axle/Gears: 4:10
I already have this cam. I got all of my parts cheap. I don't have a stall yet. Should I run a stall if I am going to run it on the street? I was thinking maybe a 2500 stall, but I haven't bought one yet. What would happen if I used my factory convertor? I know these are probably stupid questions and I am going to get flamed for this, but this will be the first car that I have had that hasn't been stock. Thanks
Old Sep 10, 2007 | 12:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock converter with that cam = absolute dog off the line.
2500 stall converter with that cam = somewhat less of a dog off the line.
3500 stall converter with that cam = pretty decent off the line, assuming the rest of the supporting cast is up to the task.
Old Sep 11, 2007 | 12:45 AM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
five7kid... what stall do you think would work well with a 700r4,3.73 gears,mildly built 350 (Holley 600 VS,Edelbrock Performer RPM intake,xe268 comp cam,full length hedman headers?) Thanks!
Old Sep 11, 2007 | 12:52 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
my friend ran a 278 dur 48/48 lift cam on his 305 600cfm edelbrock, tried to run with stock converter on 700r4 ..... HAHAHA, put a 2600 in it and it was good didnt seem to have power like it should of, maybe it was a tired motor or hap hazardly tuned, either way he burned a hunk out of the number 4cyl on it. alot of trans guy say only put a high of a stall as you need, crane's tech line will help you size up the proper stall speed, give them a call, also Jegs has a great tech center that can size you up also
Old Sep 11, 2007 | 11:53 AM
five7kid's Avatar
A dyno plot is about the best way to choose a torque converter.
In my experience, the advertised cam powerband low end is always lower than the stall it takes to get good performance.
The 2nd best way to choose a torque converter is to start off with one you know stalls to low, and observe what RPM the engine power comes in.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
