Diesel swaps anyone?
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
with the potential torque power of turbo diesels , has anyone thought of tryin to drop one in a third gen? anyone see the duramax 64 impalla on mtv?
http://www.dieselpowermag.com/featur...max/index.html
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Diesel swaps anyone?
I'm working on it, so don't worry. It takes time and money and talking about it before it happens makes people here upset.
When it shows up it will have a good story with lots of pics as well.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i've thought about it.. definetly a project i will do in the future.. but not anytime in the next 20 years.. lol
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
what engine you guys plan to use? the one engine i can think has the best chances of workin is the Duramax engine. The Cummins is probably too long and who wants to put a Ford in their third gen.
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
6.2 or 6.5 with a TH400 would be the way i would go. They spin fairly fast two. As much as i like fords, i like the 6.2 any day over the the NA 7.3.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a major issue would be the weight of the engine.
Car: 1983 G20 Chevy
Transmission: 4L60
Think the old 6.2 cannot run.
http://www.thedieselpageforums.com/t...or_320x240.wmv
http://www.thedieselpage.com/readers/kolkman.htm
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
That is just too cool!
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 87 GTA
I found the buildup online. It's in 3 parts, but automatically forwards, the the next part. by itself.
http://www.mtv.com/overdrive/?id=1557647&vid=145907
Car: 1984 Trans Am
weight of the motor will not be an issue by the time i start my build.. i'm sure in 20+ years, if they still make diesels, they will be as light as a sbc..
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Weight will always be an issue. Because of how the engines run (Basically by detonation) the sealing needed on the heads because of boost, and the significant torque output, to be reliable they will always have to be massively heavy: Not a problem in a truck. Although technically interesting, putting the Queen Mary engine in a rowboat seems to me a project of questionable merit.
...just my 2 cents.
TA
...just my 2 cents.
TA
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Just a thought.....Global West Competition springs have an ungodly spring rate. Might be able to use those along with beefing up the front end with a tubular A frame crossmember and lower control arms.
Car: 87 GTA
Anybody know the fully equipped weights, of a Gen 1 SBC & auto tranny, compared to a fully equipped turbo diesel, and Allison? Curious about the auto tranny equipped diesels, but no too many people are going to buy a 2007 tranny. I don't know of any older auto diesels.
Transmission: 200R4
Check out this "Pimp Your Ride" '65 Impala with a 800 hp Duramax and Allison.
It seems to ride well with big block springs....so you can guess that the motor combo is somewhere in the big block range.
Car: 87 GTA
Yeah, I've seen that car...Between the extra weight, I'm also curious about a diesels height. We all know it is taller than a SBC or BBC, hence the monster cowl hood on that Impala.
Hello, Michael
Aug 20, 2015 03:19 PM
