85 camaro engine swap
Old Sep 1, 2007 | 12:56 AM
piticu667's Avatar
hey guys just bought an 85 camaro v6 2.8L the engine is shot to hell. Block is cracked . I plan to swap it. The car has a standard tranny which I would like to keep.
Any suggestions for the engines. I know that if I get a V8 i need to change the tranny and standard trannies are hard to come by. I am new at this so please bear that in mind when you make the suggestion. Also if you feel like please let me know where i can find a good junk yard in Toronto.
Old Sep 4, 2007 | 04:13 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 85 camaro engine swap
You need an 87 or newer 2.8/3.1/3.4 from either an f-body or an s-truck. The 3.1 from the Isuzu Rodeo is also the same. Any of these engines will drop in with very little modification and you will be very happy with the results.
Good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
