swapped tbi to tpi F/P won't shut off now
Old Nov 9, 2007 | 09:17 AM
joshuasmith580's Avatar
Hi i made the swap about two years ago to tbi from carb then i switched up to tpi and changed the fuel pump again,, i basically picked up the engine and hareness all sensors and relays and dropped them in my car.
But now my fuel pump will not shut off when i turn on the key, it will start and run the car but i think it's supposed to fuel prime and stop. If you have any suggestions please leave me a message or email me joshuasmith580@comcast.net
Thank you Joshua Smith
Old Nov 9, 2007 | 09:41 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: swapped tbi to tpi F/P won't shut off now
Sounds like a stuck relay. Swap out your fuel pump relay and see if it fixes it.
Old Nov 9, 2007 | 09:48 AM
I have already bought two and it has not fixed it, i wondered if it's the fuel pump wire that run to the aldl connector, it may have gotten crossed up because this car was originally carbed
Old Nov 9, 2007 | 09:57 AM
also i have a generl question I am new to this forum I can't seem to reply to classified ads i've been wanting to buy stuff but connot get through other than pm's
camaro11j
Sep 19, 2018 08:49 AM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
