v6 to lt1 possibly?
Old Nov 12, 2007 | 03:44 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
v6 to lt1 possibly?
ok so i found access to a garage. and i found a 94 lt1 5.7 comes with tranny engine harness and pcm. its the complete stock engine with all sensors and the radiator as well. what else would i need. it would be going in a 1985 2.8 with a t5 manual. im not thinking i would need much else except the front end suspension. and yes i did read the post on swapping a v8 into a v6
Old Nov 12, 2007 | 05:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Combine the V6 to V8 swap sticky with the LT1 swap sticky, and you'll be there.
The only suspension changes are the springs and sway bar.
Old Nov 12, 2007 | 05:27 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: v6 to lt1 possibly?
thanks i found the lt1 swap guide. looks like it covers everything. and if what the guy is selling is actually what he's selling then i should have everything but the fuel pump, exhaust, and motor mounts. now the question can i get it all done before i have to go on deployment
Old Nov 12, 2007 | 07:41 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Late nights at the auto hobby shop...
Those were the days...
Old Nov 12, 2007 | 08:37 PM
five7kid's Avatar
They wouldn't let you do "hot rod stuff" back when I was in. For instance, I was taking the engine out of the '57 and putting it in another '57 with no engine or exhaust. All I had was headers, and they wouldn't let me bolt the headers up in the shop. I had to lay them in there, drag the car out of the shop, and hook them up elsewhere.
Hopefully they've loosened up a little since then.
Old Nov 12, 2007 | 11:19 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
from what ive been hearing you can do what ever you want in the garage. you just cant leave the car in there over night. they have a storage lot next to the place though. another thing i was wondering about is camshafts. would any 5.7 cam work? i cant seem to find any when i did a search for a 94 5.7 but when i choose the 3rd gen years i get a cam for those 5.7's
Old Nov 12, 2007 | 11:52 PM
five7kid's Avatar
You need a roller cam, and one with the longer pin to drive the water pump/Opti.
Old Nov 13, 2007 | 06:14 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Most manufacturers have a selection of cams made specifically for the LT1, don't do a search for 5.7's but specifically LT1.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
