tpi into non tpi car
Old Dec 22, 2007 | 03:11 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
ive got an 86 firebird 305 5spd, carb motor, i just purchased an 86 tpi engine with a 350 block, so it has the 305 heads, the injectors were changed, i was just wondering how hard the motor would be to swap in, it has the computer with it, and all accesories, sensors ect.
i know ill have to have a chip made for the 5spd, how much do those run? any ideas how much power the motor should make?
Old Dec 22, 2007 | 03:41 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: tpi into non tpi car
If the harness came out of a bird,you should have no problems at all.
Camaro and firebird tpi engines have different eng. harnesses.Only because of batt. location.Camaro=pass. Firebird=driverside.
Old Dec 22, 2007 | 03:46 PM
Engine: 2002 Ls1
Transmission: t-56
yup came out of a t/a, dyno 2000 says the motor should make 250hp to the fly with lg4 heads and the 305 cam
Wade787b
Sep 29, 2015 01:15 PM
NBrehm
Aug 25, 2015 11:49 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
