how to swap a stock TBI to stock TPI
Old Dec 28, 2007 | 06:00 PM
rs90 driver's Avatar
How do you swap a 1990 stock TBI 305 to a 1990 stock TPI 305? What do I need?
Old Dec 28, 2007 | 09:37 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: how to swap a stock TBI to stock TPI
Intake, camshaft, exhaust, y-pipe, cylinder heads, all sensors, ECM, engine wiring harness.
You can keep your short block if you ditch the peanut cam.
Old Dec 28, 2007 | 09:40 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Allright, this may be a dumb question, but what is B-O-P?
Old Dec 28, 2007 | 10:01 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Buick - Oldsmobile - Pontiac
Old Dec 29, 2007 | 09:49 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Oh, Thanks!
Old Dec 29, 2007 | 02:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Add fuel pump to that list. Probably easiest (best advised) to just drop the tank in the receptor car and put in a new TPI pump.
Old Dec 30, 2007 | 07:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you read the tech article on this website that describes the procedure? Its outdated now but it will get you started. Not to mention the hundreds of other threads on this topic should help you out.
Good luck and get ready to enjoy all the new power and torque the TPI swap will bring you!
MustangBeater20
Oct 29, 2022 09:20 PM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
