Newbee
Old Jan 16, 2008 | 08:30 PM
hellraiser6's Avatar
Car: 82 Camaro
Engine: 3 350's
Transmission: 3 t350
Newbee
I have an 82 camaro with a 305, also have a complete L31(minus intake). Wanting opinions on this swap!
Old Jan 16, 2008 | 09:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Opinion? Remove the 305, get a Vortec spreadbore intake, put the 305 control stuff on the L31.
Old Jan 16, 2008 | 09:30 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: Newbee
welcome to the forum.
Old Jan 17, 2008 | 04:53 AM
Car: 82 Camaro
Engine: 3 350's
Re: Newbee
305 is currently carborated, and I want to stick with that on the L31
Thanks for the welcome!
Old Jan 17, 2008 | 07:09 AM
Re: Newbee
What's the question?
Turn the bolts. Done.
You'll need a different intake manifold, is the only thing; Vortec heads have the intake ports in a different place. I'd suggest the Edelbrock Performer for Vortecs. You might also need an electric fuel pump, as I don't think that block will support your mechanical one; I'd mount it on the frame, right by the engine, where the existing lines can hook up to it.
Old Jan 17, 2008 | 03:49 PM
Car: 82 Camaro
Engine: 3 350's
Re: Newbee
I am also looking to beef up the L31, any ideas as far as Crank, cam and so on. I have worked on cars all my life, but it has been only maint. I have no idea as far as what cams work with what, so any advise I can get will be greatly appreciated.
Old Jan 17, 2008 | 06:48 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Newbee
An L31 long block is a great place to start. It has powdered metal rods, and a decently strong cast crank to go with it. You should just use what you have now and then go over to DIY PROM and learn how to tune that thing. Tuning is power!
Old Jan 17, 2008 | 07:11 PM
Car: 82 Camaro
Engine: 3 350's
Re: Newbee
it currently has a spun barring. So the crank is need of some TLC. Also I am not running any computer or fuel injection. Wanting Old School! (Carb)
xaftmx
Mar 4, 2015 10:41 AM
graysmoke
Mar 10, 2014 03:31 PM
91skybluez28
Nov 6, 2006 02:36 PM
9SecV6
Aug 29, 2006 06:00 PM
