what factory gm cam shall I insert ----->
Old Feb 4, 2008 | 06:26 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
hey guys i don't want to do any head work to accommodate the cam because when i eventually go forced induction I will be ditching these heads most likely any how and the cam so i want a used roller cam with as close to .450 lift as possible and i figure a factory cam would be the cheapest.
thanks for reading!
Old Feb 4, 2008 | 11:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
LT1.
Old Feb 4, 2008 | 11:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: what factory gm cam shall I insert ----->
Originally Posted by five7kid
LT1.
+1
LT1 cam of some sort
or even a Lt4 non hotcam
Old Feb 5, 2008 | 06:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
LT1 cam is a bit small for an 11:1 engine (even with 10.4:1 and aluminum heads the stock LT1s have spark knock issues because the cam is so small, and a big 117* LSA), but the regular LT4 cam wouldn't be a bad choice.
Look at Crane's website though, they have lots of high performance cams that are low lift - called "stock lift rule" cams... most are around .400 or so lift, but duration from as little as 190* @ .050 all the way to the 240-250 degree range. Maybe worth a look.
Old Feb 5, 2008 | 10:38 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I think that the stock LT4 cam is best as well...
I prefer used!
Old Feb 6, 2008 | 12:13 AM
sradams21's Avatar
Car: 1991 firebird
Axle/Gears: 10-bolt 3.08
I'ld agree with everyone else and say a stock LT4 cam. Air_Adam is right Crane Cams does have the "stock lift rule" camshafts but their all way to tight on the Lobe Serperation Angle "LSA" for computer controlled or forced induction. Their lobes are between 104-108* lsa.
Old Feb 6, 2008 | 07:10 PM
Air_Adam's Avatar
Sounded to me like he was just looking for a cam to use with the heads he has for now, and pitch the cam/heads later for a non-NA setup...?
Old Feb 6, 2008 | 07:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
depending on the duration, a 108 lsa cam will notbe that bad on a TPI computer...just need to really tweek the idle and low rpm part throttle settings to handle the overlap that cam has. Its been done before
Old Feb 8, 2008 | 01:18 PM
mxcrazed's Avatar
Engine: None
Transmission: none
yea I will probably go with the stock lt4 cam and 1.5 rockers. and you are correct i want it to work with my heads as they are now, but I also want ti to cost $30 and on top of that I could run a little boost on those cams because they have enough lsa
Old Feb 8, 2008 | 01:45 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
zz4 cam wouldnt be too bad either
Old Feb 8, 2008 | 02:59 PM
mxcrazed's Avatar
Engine: None
Transmission: none
zz4 has a little too much lift for my heads oh well
Old Feb 8, 2008 | 03:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
could run new springs and shim them up with offset locks to gain total safe lift of about .525" lift. then you could run a hotcam u can snag a hotcam used for 100 bucks or so
Old Feb 8, 2008 | 03:50 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
You can snag MY used ZZ4 cam for $75 plus shipping.
Bill
Old Feb 8, 2008 | 04:33 PM
mxcrazed's Avatar
Engine: None
Transmission: none
$75 dollars but still too much lift
Old Feb 8, 2008 | 07:36 PM
Burnout91's Avatar
Engine: Modded L98
I ran this cam (240 rwhp) with ZZ4 valve springs on stock L98 iron heads (disclaimer- stock except I trimmed the bottom edge of the valve locks .030";, deburred the trim to eliminate stress risers...) for 10 years and saw a few trips to 6K. It works. Bill
Old Feb 8, 2008 | 10:43 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
hes right if you want higher lift you can buy cheap +.050 keepers basically anywhere as long as theyre 7 degree. the also sell +.050 retainers that i know manley sells that fits stock size springs.
BTW burnout91 what other mods did the car have when it dynoed 240whp? 350 i assume?
Old Feb 9, 2008 | 10:57 AM
Burnout91's Avatar
Engine: Modded L98
When it made 240 hp, it had the ZZ3(4) cam, Edelbrock TES (the dual diameter primaries version), Edelbrock Hi-Flo base, SLP runners, Bosch 22# injectors, and most of the minor / free mods. Yes, 350 cu. in. Bill
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
midge54
Aug 29, 2015 09:51 PM
Wife'sCar
Aug 22, 2015 01:46 PM
fonzie85
Aug 13, 2015 11:50 AM
