tpi air cleaner help....
Old Mar 17, 2008 | 07:29 PM
challenger71's Avatar
Car: 71 Challenger, 70 duster, 89 iroc,
Engine: hemi and 440
Transmission: a-833 4 speed
I recently acquired a tpi air cleaner housing but I am not sure if it is right. I will try to describe it to the best of my ability.
The one I have has the normal top that looks like a "V". That bolts to another piece that looks the same but houses the 2 filters, but the filters are open underneath with no protection. Is there something missing that goes below that, like another plastic piece? I can't see the filters just being open like that.
I am swapping a tbi to a tpi setup, that is why I do not know.
Old Mar 17, 2008 | 07:42 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: tpi air cleaner help....
on the camaro tpi air filter housing there should only be openings on the sides of the lower part. alot! of people cut the bottom off so the filter has no restriction and is open as you call it.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
