trnny stuck to motor
Old Mar 18, 2008 | 12:57 PM
xpbxwrecked1's Avatar
Car: 87 mustang gt 89 camaro
Engine: 302 355 tpi
Transmission: manual
Axle/Gears: 3.55 and 3.42 posi
i am pulling my motor...when i lift the engine and try pulling it doesnt separate from the manual tranny...there are only 6 bellhousing bolts right? i see that there are a couple dowel pins..do these need to be knocked out? also i should be pulling straight forwards?
Old Mar 18, 2008 | 01:10 PM
Re: trnny stuck to motor
Yes there are 6 BH bolts.
No you don't need to knock the pins out; but you may need to pry the motor and trans apart a bit.
Be sure you do it in such a way that whenever they finally DO separate, the motor doesn't swing forward and punch through your AC condenser. I.e., don't put a whole bunch of pulling force on it and then start prying, lest you get an ugly surprise.
Old Mar 18, 2008 | 01:23 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
You did unbolt the torque converter correct?
Old Mar 18, 2008 | 02:20 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Umm...not in a manual tranny.
Old Mar 18, 2008 | 02:43 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Well, look at that...
Then with the manual, you'll want to make sure the input shaft slides out
fairly level.
I find it easier to remove the transmission as any angle between the transmission
and engine will add additional resistance against the disc.
Try engaging the clutch to free up the disc, it might help until the engine pulls away (which is not much as the plate will engage as the distance increases).
Old Mar 18, 2008 | 02:54 PM
Hope you know I was just messin' around with you. I almost said the same thing until I re-read his post.
Old Mar 18, 2008 | 02:55 PM
ljnowell's Avatar
You know, a funny story. Picture a normal size cherry picker with a 454all accessories, intake, distributor everything, with a th400 bolted to it. All being pulled from a 80's chevy 1 ton dually pickup. It wouldnt come, wouldnt come, kept hanging on exhaust, etc. I had the whole front panel (header) panel off. When it came out, it practically lept out of the truck, and then proceed to turn the cherry picker over. I was holding onto the top of the boom, and it pulled me off my feet, a good 8 inches in the air. Which was cool, cause im 6.5ft tall and go 300lbs.
Old Mar 18, 2008 | 02:56 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
It's all good, I just assumed and should have read his sig., or profile.
Old Mar 18, 2008 | 05:37 PM
danandamy's Avatar
Car: 86 Camaro
Be sure you have a floor jack under the tranny to support it as you pull it apart.
Old Mar 18, 2008 | 07:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The input shaft needs to slide out of the pilot bearing (seen them seized in) then out of the clutch splines. Alignment is usually critical, more so when installing.
It might be a lot easier to pull the engine and tranny out as a complete unit then split them when they're out of the car. The other option is to pull the tranny out first then pull the engine. There won't be anything supporting the tranny other than the rear mount once it's disconnected from the engine. The rear mount won't hold it up.
Cameeeero
Sep 18, 2015 04:00 PM
hydrolic144
Sep 8, 2015 06:55 PM
JHX
Aug 29, 2015 02:30 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
