engine wont crank on swap
So about a year ago I swapped out my 5.0L on my 85Z28 for a 5.7L gmgoodwrench. I put the engine and tranny together about a year ago and havnt had time to really work on it. So i try cranking the engine manually today and it wont budge at all. the starter, sparkplugs, distributor are all out and the shifter is in neutral. Does anyone have any idea what this problem could be>??
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: engine wont crank on swap
Is there moisture in the place where you had this sitting?
Humidity anything?
Humidity anything?
Last edited by calamitascamaro; Apr 3, 2008 at 03:21 PM. Reason: Automerged Doublepost
Transmission: 4L80E/4L80E
Car: Blue 89' RS
Engine: 5.7L
have you always had the plugs/dizzy out? or did you just take them out?
the easiest way to turn these engines is to get a socket and torque wrench and stick it on the middle bolt to the harmonic balancer... then turn clockwise. if this does not work, it may be rusted... i dunno!
Car: 91 maro
Axle/Gears: 373 locker
wd 40 in plug holes fill them pretty good let sit try another day.if turns.start up turn off change oil.i found a rebel 750 bike at the dock 4-5 feet under salt water.dont think it was there long did wd-40-pb blaster cleaned carb used a different tank fired up ran like crap.i was amazed.me and my dad were fishing and we threw a ice pick and chain hooked to my dads pickup and pulled it out.
