Bracket Problem, Need advise
Old May 1, 2008 | 03:21 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I got a 95 350 out of a tahoe that im going to swap into my camaro. It doesnt have any accessorie brackets. I need the Alternator and Power steering pump bracket. Where can i find these? Do i need to get the factory brackets for a 92 camaro z28? I went to the gm dealership today and they told me its all one piece. I need advise, thanks.
Old May 1, 2008 | 03:57 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Bracket Problem, Need advise
Junk yard, If your in Central IL I now of few good junk yards.
Old May 1, 2008 | 04:01 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Called like 30 today and none of them had camaro's. Will this work for the alternator? http://www.jegs.com/p/JEGS/761124/10002/-1/10363
Old May 1, 2008 | 04:26 PM
bigj350's Avatar
I not sure, I'm probably wrong but it doesn't look sturdy on the bottom. I think the bottom bolt needs a mounting hole. The Power steering and alt. are on one bracket. If I took a picture of my brackets would that help you or do you have a good idea of what your looking for?
Old May 1, 2008 | 07:53 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
It would help alot if you took a pic. Something like this should work right? thanks. http://www2.partstrain.com/store/?D=...982+9891&Nty=1
Old May 1, 2008 | 09:05 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Or should i just get the factory one piece? It comes with a support link, that looks to bolt on to the exhaust manifold but im going to be using headers.
http://paceperformance.com/index.asp...&ProdID=180524
Old May 2, 2008 | 05:23 AM
bigj350's Avatar
That looks about right. That looks like the backside of it in that picture.
Old May 2, 2008 | 11:03 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
You mean the factory Gm part? My concern is the bracket that goes on the driver side bolts in to something on the head that i dont think i have.
Old May 2, 2008 | 02:30 PM
bigj350's Avatar
The gm factory one is what I was referring to. Heres what mine looks like. I think the GM factory one piece all you need. I didn't see any other brackets.
Old May 2, 2008 | 02:55 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Thanks for taking the time to take those pics. Im not sure if that would work for my setup or not because im just gonna run an alternator, power steering and water pump. I orded this part today, it says it will fit. http://www2.partstrain.com/store/?D=...982+9891&Nty=1
Old May 2, 2008 | 03:43 PM
bigj350's Avatar
I love an excuse to take picture of my car.
Squeaky8791
Feb 5, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
sreZ28
Aug 14, 2015 07:48 PM
