350 to 454!
Old May 1, 2008 | 08:59 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
350 to 454!
Sorry for the long post, got a 89Z with a L98 TPI and a 68' Nova II with a 454, and i got some questions.
I've always been a BBC fan, love the torque and power. I bought a Nova from a friend and has a fresh 454 TBI in it, and i want to swap the engines with the two of them. I always wanted a Nova for a daily driver, and a 454 doesnt cut $4 a gallon. I also have always wanted a big block in my third gen, as its been handed down in the family, and its mine to do what i want with. **STRIP CAR!!**
I know what im doing ECU/Harness wise, tranny wise etc. But i mainly have these questions:
Once the 454 is set in the Z, what should i do suspension wise? I already got a 12 bolt ford rear in it, and have a powerglide that i plan on throwing in there with the package. Also, the Radiator, howes that going to hold? New? What kind?
Now for a nova question..
Once i get the 350 TPI in the nova, im going to have a problem with the air intake sense its MAF.. So, i want to find a way to throw a cold air intake on it without giving the MAF sensor hell. What should i need? My buddy has an 89 GTA with a CAI on it, and he used the same tb hose and threw a cold air intake on it from a dodge durango, and worked out fine.. im thinking i will do the same, but it will just be turned 180 degrees.
Again sorry for the long post, but appreciate the help!
John
Old May 1, 2008 | 11:11 PM
Engine: THREEFIDDY!
Re: 350 to 454!
bumpp??
Old May 2, 2008 | 08:41 AM
Engine: THREEFIDDY!
Re: 350 to 454!
To the TOP
Old May 2, 2008 | 07:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 350 to 454!
If you want a BBC in your third gen, read this
https://www.thirdgen.org/forums/engi...swap-info.html
If you want EFI on your BBC, you're on your own.
Old May 5, 2008 | 10:06 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: 350 to 454!
Do you plan to make a strip car with TBI? or do you plan to swap to carb?
I have just never heard of someone swapping a 454 in to a car for the strip and keeping it TBI. If it is going to be a strip car I would think high rise single plane, no?
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
Vojtush31
Oct 11, 2015 01:07 PM
90formulaVortec
Sep 7, 2015 07:17 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
