89 Firebird's 2.8L V6 to 3.8L V6 Turbo
Old May 12, 2008 | 08:43 AM
DAB90's Avatar
Hi, I'm completely new to this site, and I don't really know that much even though I'm taking auto in my high school. Right now though, I'm getting an 89 Firebird with 2.8L V6 engine, but I want to switch that out for a 3.8L engine instead. I've thought about switching to V8, but I thought that would take too much work and would be too expensive for me. So I decided to try and get the turbocharged 3.8L instead. Anyway, what I'm asking is, a rough estimate on how much it would cost me to do this swap. I can probably do the swap myself with the help of some of my friends, but I'd like to know how much it would cost if I wanted it done in a shop. Just a rough estimate would be okay. And about a guess of how many days it might take too would be nice.
Also, this swap sounds like a good idea, right? Not really all that sure, since one of my friends keep trying to convince me to go for the 5.7L V8 engine, and then maybe add a turbo if I have any money or time left.
Old May 12, 2008 | 09:03 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 89 Firebird's 2.8L V6 to 3.8L V6 Turbo
^ Why don't you consider slapping a turbo on the 2.8 V6 (Click Here, then Click Here)? Come join us over in the V6 section, as there are plenty of guys over there that will help you get started in your new venture....
-Rob
Old May 12, 2008 | 09:24 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
A 3.8 turbo WILL cost more than a V8, but since you already have a 2.8, you should check out what there is going out with the guys turboing those. It's pretty impressive in my opinion.
Old May 13, 2008 | 08:29 AM
DAB90's Avatar
Hmm, alright, I'll try just adding in a turbo to my 2.8 then. And I thought a 3.8 would be cheaper cause of the amount of work and other parts, since I tried looking up prices for new engines and they're all starting prices at about 800 or 900 dollars from the 2.8L to the 5.7L, including the turbocharged 3.8L
I'll try putting in a turbo then. I just wanna be able to beat my friend's 86 or 87 Camaro with 350 engine. Not sure how long it took, but I think he said he was able to go from 0 to 90 in just a few seconds, from one stop light to the next.
Old May 14, 2008 | 12:50 AM
eeeeeefirebird's Avatar
just so you know, putting anything besides another 2.8 or a 3.1 in your car is going to cost alot of money. turbocharging anything is going to cost a lot of money. but plenty of people swap v8s, turbo 2.8s and put the turboed 3.8 GN setups in these cars. nothing is impossible just check out the rest of the engine swap thread and the v6 thread for other opinions.
Old May 14, 2008 | 05:45 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Do a search, you have plenty of options.
Old Aug 9, 2008 | 06:30 PM
liveyourself's Avatar
Car: 1986 firebird 2.8l v
Engine: 2.8l v6
Transmission: automatic =[ looking for 350 or 305
so what kind of turbo should i get. a link plz
Old Aug 17, 2009 | 01:08 PM
autouzi's Avatar
Car: 1988 Camaro RS
Engine: 2.8l V6
Where do u get a turbo for a 2.8l camaro
Old Aug 20, 2009 | 04:48 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Well you have to do some research and find out what turbo will best fit your needs for what you want to do with the car and how long you want it to last and how much power you want to make.
then you go buy a turbo that fits your combination, and then the fabwork starts!
Old Aug 20, 2009 | 11:13 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Unless you are particularly attached to your car or it's in fantastic shape, your best bet is to just find a v8 car to start with. If you do want to keep your current car no matter what, it would benefit you to spend some time just researching for yourself. Asking questions like this only gets other peoples opinions as answers (like mine), research it yourself and develop your own opinions on what is best.
Old Aug 21, 2009 | 12:55 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
A junkyard 350 swap is about as cheap as it gets, I got my shortblock for $45 from the local you-pull-it, a complete motor would have been $129 from the same yard but I wanted aluminum heads.
Old Feb 22, 2010 | 12:18 PM
G92RS's Avatar
Car: 92 RS Camaro
Engine: LHO 3.1L V6
Transmission: 700 R4auto
well, if your like me and u realize that doing these sort of things takes more patience and research than anything else, then u should research your engine a lil more theres a guy on here who pieced together his own rebuild kit and turbo for the 3.1L which if u dont know the 3.1L is nothing more than a slightly stroked 2.8L same block different heads and internals... and yes there is a version that was made for a year or two by mclaren that is a 3.1L turbo, not sure of the exact specs however but none the less pulling atleast 300 ponies out of this engine is doable but yes its going to take alot of money and time... that being said, if your aiming for a daily driver that will give u a good quarter mile snap if u know how to work on cars even a little bit or have someone with the tools and knowledge to help u.. it IS possible to pop a 350 off the line due to the simple fact of "Power to weight ratio" a stock 305 in these cars didnt even break 200 horses and because the car is relatively light i will get up and gallop! so if u have a few grand i suggest rebuilding your engine and tranny first off, then look into the bolt ons i.e. pulleys which jegs does make a pulley kit for by the way, turbo suspension and lighter wheels make a great start heres some info to get u going http://racetransmissions.com/store/p...roducts_id/408
https://www.thirdgen.org/forums/v6/3...arts-60-a.html
oh and the guy that started the forum to the second link... u really should listen to him because despite the crittics his V6 is quite a monster, theres vid of it on youtube!!
Old Jun 4, 2013 | 03:42 PM
David Kittredge's Avatar
I'm completely new to this site too so sorry if this is a bad place to post this. But im having the same issue as this guy i have a 2.8l v6 in a 87 camaro. but i have a 3.8l v6 supercharger from a gm engine. and i was wondering if i swapped out my heads and a few other things could i get the supercharger on the 2.8l? any help would be awesome.
Old Jun 4, 2013 | 07:28 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Theres no heads to swap to get the 3.8 supercharger to fit thw 2.8.
It will be completely custom, and usually ends up as a remote mount, since sitting on top of the engine usually has it sticking through the hood.
neilb
Nov 15, 2007 11:59 AM
89_RS_Mike
Dec 19, 2001 03:26 AM
85f-bird
Aug 7, 2001 12:22 PM
karfreek
Mar 27, 2001 07:43 AM
85f-bird
Jan 31, 2001 09:54 PM
