Intake questions
Old May 28, 2008 | 10:05 PM
wayfastf150's Avatar
Intake questions
Hey guys Im building a 350 right now, the heads have numbers 140101081 k207 Im assuming those are "081" heads that everyone talks about? The intake Im planning to use is a holley weiand 7546 topped with a edelbrock performer 1405 which is a 600cfm carb. Will the intake bolt up to the heads or will I have to elongate the middle holes?
Old May 28, 2008 | 11:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The intake will bolt to the heads, but unless you have a pretty big cam, a lot of stall, and steep gears, it isn't a very good choice.
The carb wouldn't be a very good choice in that situation. It wouldn't be my choice in any situation, but that's another story.
Old May 28, 2008 | 11:18 PM
Re: Intake questions
I already had this intake and carb which is why I was going to run it. What cam would run good with this setup and not require machine work?
Old May 29, 2008 | 12:17 AM
five7kid's Avatar
Not much. That's an aggressive intake, and it requires an aggressive cam with a lot of lift.
Old May 29, 2008 | 12:35 PM
I was reading the specs on the intake it requires a cam with 260 duration @.50. If not I would have to get a divider plate. As long as the cam I get has less than .470 of lift I dont have to machine the heads right? Im thinking of running this cam with a divider plate. http://store.summitracing.com/partde...2&autoview=sku
Old May 29, 2008 | 07:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What pistons do you have in that engine? You really should find out what your compression ratio will be, as its really easy to get it too high with the small chamber 305 heads on a 350. They are pretty good heads, just have to be careful to keep things like CR reasonable.
Go to Google and look for 'compression ratio calculator' and put in your engine's info, and make sure you're still 'in the ballpark' so to speak. Those heads have a pretty good chamber design, and aren't really detonation prone like some others, so as long as you can keep it at or below 10.5:1 you should be ok. Those heads are 58cc btw.
I ran a set of '601' castings with 53cc chambers on my 350 for awhile, and it was really on the ragged edge... I was always playing with the timing to keep the pinging under control on a hot day (compression was well over 11:1 with my combo). Ran like a raped-ape though!
As for the cam... in a carb'd application with 10-10.5 CR I would suggest the Comp Cams XE274. Its a big cam, but its still a pretty civilized cam... idles a little choppy, but still idles well, and makes good power from about 2000 rpm and up. Thats what I have in my 350 right now.
Old May 29, 2008 | 09:26 PM
Their just stock flat top pistons. I was also looking at the Edelbrock performer plus 2102 cam, which is the one I think im going to go with. I just have to put a divider plate in the intake.
Old May 29, 2008 | 11:45 PM
five7kid's Avatar
Peaky intake + peaky cam = really peaky engine.
You can do a lot better on the cam.
Old May 30, 2008 | 05:54 PM
Whats the most lift I can run with stock heads with out getting them machined?
Old May 30, 2008 | 07:04 PM
Air_Adam's Avatar
Around .460 or so is the safe limit.
Old May 30, 2008 | 11:05 PM
Ordered my cam, gaskets, oil pan, and distributer tonight. Also got the divider plate for the intake. The cam I went with was a Lunati 60101LK. Got it brand new off ebay for almost $100.00 cheaper than I could off summit.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
