Carbed pre 90's small block or LS1-7 in a 3rd gen whitch is better???
Old Jun 16, 2008 | 11:55 PM
BG84FBIRD's Avatar
Car: 84 Pontiac Firebird
as i said i'm wonderin whitch so you guys or gals think is better a pre-90's built smallblock or an LS1-7??
Old Jun 17, 2008 | 12:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The LS-series of engines are arguably the best available now. I wouldn't put a carb on one, though.
But, "better" is impossible to answer, because use, budget, down-time, etc., aren't included in your criteria.
Old Jun 17, 2008 | 02:31 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Carbed pre 90's small block or LS1-7 in a 3rd gen whitch is better???
what are you wanting to do? street strip or both? How much of a budget? MPG or performance?
Old Jun 17, 2008 | 02:55 PM
Justbrilliant5's Avatar
LS1 go for it. I estimate about $5k for a used one installed with trans, harness and accessories.
Old Jun 17, 2008 | 03:23 PM
five7kid's Avatar
$5k would get you about half way there, especially if you're talking installed.
Old Jun 17, 2008 | 03:28 PM
3rdgenmaro's Avatar
Car: 88 IROC
really? I thought that you could get a good pulled unit for about $2500. with a hawks k-member and maybe headers that would put you at $4k. Throw in a good shifter, exhaust tie-in, and fuel pump, be around $4500
what else am I forgetting? Ive thought about this swap, but I didnt think it was that expensive.
Old Jun 17, 2008 | 04:35 PM
five7kid's Avatar
Lowest I've seen is $2500 with auto tranny, and that was an oddball. $4k for LS1/T56 is more typical.
K-member is around $500 w/o a-arms. Conversion mounts are cheaper, but you'll need to modify the front crossmember if you keep AC. You still need a rear crossmember. Headers are $800 for the "standard" set. Good custom exhaust work is expensive. You need a different fuel pump. Gages don't work as-is.
It can be done cheap, but to do it right is going to run you more.
Understand I'm not putting down the LSx swap - after all, I have one in progress.
Old Jun 17, 2008 | 09:23 PM
BG84FBIRD's Avatar
I sisn't mean put a carb on a ls motor but what i meant was do i continue building my 407ci stroker or transplant an ls7 t56 combo? i want the car to be a street,roadcourse,drag car. my budget is non existant,and my down time will be as long as it takes to do it right!!!
Old Jun 17, 2008 | 10:28 PM
five7kid's Avatar
Then without a doubt, LS7.
Old Apr 11, 2010 | 03:29 AM
BG84FBIRD's Avatar
Old thread I know but the thought came to me, Do you guys think putting a LS series engine in a 3rd gen is kinda the same as putting an ls1 in a non-GM or is it acceptable??
Old Apr 11, 2010 | 10:41 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Two years later and your still thinking about it? Putting an LS motor in a 3rd gen is competely acceptable. Why wouldnt it be? There are a lot of people on here that have that swap.
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
