starter wont start new motor
Old Jun 19, 2008 | 05:09 PM
sickwitstick's Avatar
Car: 87 IROC-Z
Engine: under construction
Axle/Gears: stock
i just finished installing the motor and now it wont start ive come to the conclusion that the starter isnt strong enough since my compression is to high. anyone have any suggestions? by the way ive tried different starters but every place i order a starter from they send me the wrong one and the bolt patterns dont match. i have a 5 speed
Old Jun 19, 2008 | 11:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you absolutely sure your battery is fully charged and up to snuff, and the cabling is in good shape?
What's your CR?
Keep hearing the LT1 starter gets the job done (153-tooth flywheel required).
Old Jun 20, 2008 | 12:34 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: starter wont start new motor
had same issue. my cr is 10.75:1 i used a summit starter. its universal for 153 and 168 flexplates(mine was 168). one thing i promis is that if you dont have a full battery it will be hard as hell to start
I have heard same thing about lt1 starter. i have one sitting around now because i have a 168 toother
Old Jun 23, 2008 | 09:48 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
check the voltage drop at the cables and starter as you try to start it.if you're dropping by more than 2 vdc ,your cables aren't big enough.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
