stock 305 equipment on 350
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
goin to just swop the block and heads and put it back togeather with all stock intake cc carb dist and all (with headers)
350block 350heads
anyone ever done this or have any info on how it will run
any advice would be great
Thanx
350block 350heads
Thanx
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stock 305 equipment on 350
It'll run just fine. Keep the 305 heads though. "350 heads" could be just about anything.
Transmission: 4L80E/4L80E
Basically what I did, except I used aftermarket 305 heads.
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
I've had a bad experience with 305 heads on a 350. It can raise the compression more then you want for the street if you're not careful, and a lot of them don't flow to good. Best bet is to look up what you have for 305 and 350 heads before deciding. Everything else will bolt up fine, as long as it's the same gen... if not the intake will take a drill or dremel to get it to work. The bolt holes may need to be elongated.
Engine: 383 Carb
Transmission: 4L60
You can end up with too much compression if this is a rebuilt 350 with flat top pistons. If it's a stock lower half with dished pistons, it'll be ok. The LG4 heads will outperform nearly all 350 heads, most of which were low-performance, low-compression smogger heads.
Car: 83 Camaro
Engine: 5.0
The 350 long block i have has never been taken apart it runs good tho the 305 ran like **** so the heads would be questionable and dont really want to pull the runnin 350LB apart right. It is a gen 1 2 piece RMS jus like my 83 305 set up.
Also already set the intake on the 350 and hand tightend it down it matched right up so everything should be good then right.
