Baddest SBC crate motor?
#51
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: Baddest SBC crate motor?
The 454 uses solid lifters, so you'll have to adjust your valves, but it also lets you upgrade to nice large cam later.
So where are these pics of this machine?
#52
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
I am ashamed to show pix of work in progress
The best I have right now is right after the engine was put in. My engine bay is filthy from all the fabrication. I didn't do anything with it because it was going to get beat up during the fabrication any way.
I will get it painted when the engine is pulled for the new engine.
Vintage Air a/c setup though
As you can see, I do not want to throw away all the work and start over with an LS or big block.
#53
Car: 91 rs
Axle/Gears: 3.50 9"
What car is that? How does it drive now with that motor? Or did you say you havent yet.
I wouldnt be ashamed of that at all!
#54
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
No doubt! Looks like a non v-8 and probably non rwd car. That's a lot a friggin work. Anyone the least bit familiar with this kind of project can see that. No shame in a work in progress. Hey aren't they all? In fact, mine is perpetually a work in progress with plateau's that look sort-of finished. Next phase I'm gonna...
#55
Car: 91 rs
Axle/Gears: 3.50 9"
#56
Transmission: WC T5
FYI, this is my torque curve from the other thread. Dynapack 3000. There was a glitch on the dyno and it got shut down prematurely. I originally wanted to run up to 5100 RPM. There really was no need to do another pull because the torque curve is going to change again when we do more stuff to it
#57
Car: 1992 camaro rs 25th aniversery
Engine: crapy 305 tbi
Transmission: blown 700r4
Axle/Gears: stock
ok so what better compared power and money plus eas of swap; i can get a 350 with 440 hp turn key crate engin come with direct port injection and a programed ecm with harness for 9,000$ but i saw u can get and ls3 for 6000$ and change a cam to get 500 hp so what better sence were talking crate egines.
I have a 92 camaro rs 305 tbi
and no i dont know much about what detail goes into and ls engine change
oh and dude before u spend 12k look at this
http://chevystreetperformance.com/454_500hp.htm
i think its a good deal
#58
Transmission: WC T5
The reason is that I found out anything with more cubic inches than that is going to require an aftermarket block due to cylinder wall thickness when running that large of a bore.
I really don't want to go to an aftermarket block so I guess I will have to live with the 383.
Maybe I'll throw a supercharger on top of that after I live it with it for a while.
#59
Car: 91 rs
Axle/Gears: 3.50 9"
Thats a good motor and has a lot of room to grow. A cam change should give you close to 500hp.
#60
Transmission: WC T5
My engine is only rated 350 ft-lbs. I got 315 ft-lbs. on the Dynapack. That's only a 10% parasytic loss which is way too low. The engine has no mods. Edelbrock Performer intake, 600 CFM carb, and block hugger headers.
The ZZ383 is rated at 460 ft-lbs. I'm hoping that it will put down way over 400 ft-lbs. at the wheels.
This is the cam it comes with: Camshaft: Hydraulic roller, 222°/230° @ .050", .509"/.528" lift, 112° center lobe
Based on your recommendation I'll see if I can wake up the motor with a new cam.
#61
Car: 91 rs
Axle/Gears: 3.50 9"
Here's a link to a 500hp zz383. Relatively small cam too.
http://www.sallee-chevrolet.com/Chev...8s/383-500.cfm
#62
Transmission: WC T5
#63
Car: 1991 Camaro
Engine: Carb'd Vortec 355
Transmission: Bowtie 700R4
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
heres my take,
if you have the money to spend, get a reputable shop to build you a motor. that way if something DOES go wrong, they are only a drive away, also, you will always get a better bang per buck if you have someone build it rather than a crate motor.
that being said, go with an aluminum block 427 small block
http://www.worldcastings.com/prods_pages/101008.htm
#65
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
i beileve they came equiped with a 4.11 ratio in the rear stock.
cool swap kenn!!
#66
Car: 89 iroc
Engine: zz383/compcam/gmpp intake/holley770
Transmission: 700r4 w/all the goodies
Axle/Gears: 4th gen 3:23w/powertrax
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
Mickeyruder
09-02-2015 02:45 PM
