305 bbl to vette 350 HELP
Old Jul 16, 2008 | 08:39 PM
rftransam's Avatar
Somebody please help me, i have a opputunity to put a 1987 Vette motor in my 1987 trans am with 305 bbl. Can this be done it has the computer and all necessary components to swap but my question pertains to all the accesories, namely the ac components and steering column will it all fit and will all the brackets from the trans am transfer. PLEASE HELP ME!!!
---ROB---rftransam@live.com
Old Jul 16, 2008 | 11:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The Vette engine will be TPI. You can put the TPI in your car, but you will need to put in a different in-tank electric fuel pump. It might be easier to put your carb stuff on the Vette engine.
Use the accessories and all brackets from your 'Bird. And the oil pan and oil pump.
Old Jul 17, 2008 | 12:48 PM
rftransam's Avatar
Re: 305 bbl to vette 350 HELP
Thank you very much for the advice, just so i know basically everything else should bolt right back on from the trans am right? If you have any other advice pertaining to this type of swap i would really appreciate it. In your opinion is it worth doing? Thanks-ROB-rftransam@live.com
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
