Need to identify a motor
Old Jul 25, 2008 | 10:52 PM
PUNISSHER's Avatar
Car: 1995 Impala SS
Engine: Golen 383
Transmission: CPT Level 3
Axle/Gears: 3.73's
A friend of mine picked up an 84 Z28 about 4 months ago from Florida and the previous owner had swapped the stock 305 with a carbed 350. This is the first time my friend has purchased an American Muscle car and really knows very little about them. He wants to buy some headers but doesn't know what 350 is in there. What's the easiest way for him to I.D. his motor?
Here's a pic he just sent me. I know the angle sucks cuz you can't really see anything.
And here's a vid of it.
Thanks for any help you guys can offer.
Old Jul 25, 2008 | 10:56 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: Need to identify a motor
cant really tell what 350 is in there unless we have block numbers and head numbers. its just a 350 almost all headers for a 350 will fit im pretty sure.
edit: tell him to get an open element.
Old Jul 25, 2008 | 10:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the casting numbers on the heads and the block.
Old Jul 25, 2008 | 11:00 PM
PUNISSHER's Avatar
Car: 1995 Impala SS
Engine: Golen 383
Axle/Gears: 3.73's
Got a specific location where he can locate those casting numbers on the block? The casting numbers on the heads are under the valve covers right?
Thanks again guys.
Old Jul 25, 2008 | 11:05 PM
Car: Camaro RS
on the drivers side on the back of the block there is a ledge should be right there. By the tranny bolts. yes under the valve covers
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.mortec.com/location.htm
The casting number on the block will verify it's actually a 4" bore block. That's as much as you're ever going to know about the engine without taking things apart.
PUNISSHER's Avatar
Car: 1995 Impala SS
Engine: Golen 383
Axle/Gears: 3.73's
Thanks alot! I really appreciate it and I know he will as well.
Thanks to you as well for the help and for that link. I'm forwarding it to him as we speak.
hydrolic144
Sep 8, 2015 06:55 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
