BBC header help
Old Aug 19, 2008 | 06:28 PM
mxbadboy03's Avatar
BBC header help
ok i'm goign a 496 bb swap in my 86 z28 i need the best advise on headers i dont want to go threw alot of ****** so wats my best deal?
Old Aug 19, 2008 | 06:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: BBC header help
The cheapest and most popular for a BBC swap is the Hooker Supecomp swap headers. They're also the worst fitting.
From there, any other header that will fit properly is more expensive.
Old Aug 19, 2008 | 06:43 PM
mxbadboy03's Avatar
Re: BBC header help
worst fitting like how and any other help?
Old Aug 24, 2008 | 09:28 AM
ronbo422's Avatar
Re: BBC header help
I've shoehorned a 572 (Dart Big-M block, Dart 345 heads, "squared" motor) into my '91 RS. I went with Ed Quay's weld-up headers, which are 2 1/4" stepped up to 2 3/8" with 4" collectors. I had to get someone to come out and tig them up in the car. They came just tack-welded so they could be adjusted once in the car. I then had them coated at Finish Line Coatings.
My current battle is with the exhaust. The collectors are inside the transmission tunnel, and there is nowhere to go with 4" pipes. I've thought about notching the frame and turning out with 45* bends, but I don't know how much that will weaken the car. I've got the Southside lift bar kit welded in the car with subframe connectors.
Has anybody seen a car with this done (4" collectors in the tunnel)? Any advice?
Thanks,
Ronbo
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
