New Vortec 350 TPI
Old Sep 29, 2008 | 06:22 PM
ProtoMaster22's Avatar
Car: 92 Camaro RS
Engine: Vortec TPI 412
Axle/Gears: BorgWarner 327 Limited Slip
New Vortec 350 TPI
Ok guys i just got done with my new engine and id like to here what ya think i had a tbi 305, now i have a TPI vortec 350 edelbrock high flow intake, edelbrock high flow runners, zz4 cam, edelbrock shorty headers, and a high flow edelbrock water pump..some imput would be nice
Old Sep 30, 2008 | 08:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What did you do about valve travel on the heads?
Old Oct 1, 2008 | 09:53 AM
10secondhopeful's Avatar
Car: '84 Z28
Re: New Vortec 350 TPI
Not half bad, but what about your valve train?
Old Oct 2, 2008 | 10:26 PM
Car: 92 Camaro RS
ok , you know something more then i do what kind of troubles will i be running into if i did nothing? thanks for the help!
Old Oct 3, 2008 | 07:31 AM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
I think what they are talking about is the valve lift. The zz4 cam has more lift than the stock heads can take. I don't know how close it is with that cam but you definitely need better than stock vortec springs, and normally the valve guides have to machined down so the retainers dont hit the seals. I don't think the stock vortecs can take more than .480" valve lift.
Old Oct 3, 2008 | 09:53 AM
Car: '84 Z28
exactly^, a good cam can be wasted if you don't have the spring lift to accommodate it. Most people don't bother with rebuilding there heads, though some get the CNC ported and polished with new bigger valves and springs. some RR arms (roller rocker) with a 1.6 ratio would do you good as well. So you can rebuild them yourself, or by some bolt on heads from AFR, or Dart, or Lingenfelter, or other good brands. but its recommended to get more spring lift. troubles? nothing really technical, except that you would be wasting power. and it might be hard on your factory springs
Old Oct 4, 2008 | 01:30 PM
Car: 92 Camaro RS
ok yes, i did put new springs and i put roller rockers that are 1.5 ratio.now my other question is will i be able to pass emissions with that cam? also will i need to rechip?
Old Oct 5, 2008 | 01:28 AM
five7kid's Avatar
Springs aren't enough unless you use offset retainers. The issue is the valve guide sticks up so high on stock Vortecs that the retainer will hit the top of the guide with as little as .440" valve opening (reports vary from .440" to .480"). The ZZ4 cam has .510" lift on the exhaust - bent pushrod city.
Remember you need at least .06" more valve travel than valve lift for a proper cushion.
You should be able to pass emissions. What year/type is the TPI you have?
Old Oct 5, 2008 | 11:15 AM
Car: 92 Camaro RS
i have the MAP TPI not the MASS flow TPI.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
