v6 to v8 swap
Old Nov 4, 2008 | 05:44 PM
91 camaro ss's Avatar
Car: 91 camaro rs?
Engine: 1985 5.7 350
Axle/Gears: 3.32
v6 to v8 swap
my name is alex im putting a sbc 350 in a 91 camaro the camaro came factory with a 3.1 v6 efi im wondering when i put the v8 in to get my motor mounts lined up they wont sit on the cross frame all the way they hang over slightly towards the front of the car and the motor wont go back any farther or it will be hitting the fire wall the motor is a gm good wrench crate motor i was wondering if maybe thats my problem but i my self thought all the blocks where the same im open to any advice thanks
Old Nov 4, 2008 | 08:29 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: v6 to v8 swap
v6 cars and v8 cars have different motor mounts on third gens.If your car still has the v6 motor mounts they need to be changed before the v8 will fit.
Old Nov 4, 2008 | 08:57 PM
jeff lucas's Avatar
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
Re: v6 to v8 swap
i just removed my v6 motor mounts off my 92 and installed v8 solid mounts for my 383 and the v8 mounts did hang off just a little bit.
Old Nov 5, 2008 | 02:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: v6 to v8 swap
yep, the V8 mounts do hang off the front of the crossmember just a bit. Just get 3 good bolts through both the mounts and frame on each side.
Old Nov 5, 2008 | 05:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The proper V8 mount holes are already there in your V6 crossmember. Put the mounts where they belong. Yes, they do hang over slightly. I'll try to get a pic of mine tonight (factory V8 car).
Old Nov 5, 2008 | 06:53 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: v6 to v8 swap
id like to see a pic of that since swapping a 6 for and 8 is one the ideas ive been kicking around. so the only thing needed for this swap is a set of V8 motor mounts?
Old Nov 5, 2008 | 11:16 PM
five7kid's Avatar
Not hardly. Read the sticky in the top section of this forum.
Old Nov 6, 2008 | 07:39 AM
five7kid's Avatar
Engine Mount Photos
Just as I was going to go take pictures of the mounts last night, the power went out.
Here they are.
Attached Thumbnails v6 to v8 swap-drivers-side.jpg   v6 to v8 swap-passenger-side.jpg
Old Nov 6, 2008 | 01:21 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: Engine Mount Photos
so those are V8 mounts? whats the differance between the V8 and V6?
Old Nov 6, 2008 | 01:41 PM
five7kid's Avatar
For the chassis side, where they sit.
Old Nov 24, 2008 | 04:48 PM
Car: 91 camaro rs?
Axle/Gears: 3.32
Re: v6 to v8 swap
i got the motor mounts in ill try and have pictures up soon i was also wondering what kinda gears the v6 came with in the rear end will they hold up to the power of a street strip v8 the car is a 91 rs
Old Nov 24, 2008 | 05:31 PM
five7kid's Avatar
Which gears: You might get close by looking at the 1991 Camaro Tech Data from the home page. Best way to find out is to pull the diff cover and look (probably need to change the gear lube, anyway).
Strong enough: Read the V6 to V8 sticky in the top section of this forum.
Old Nov 25, 2008 | 11:17 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: v6 to v8 swap
if your car came with an automatic transmission, a '91 V6 should have a 3.42:1 gear. This is plenty strong for a mild 350
Old Nov 26, 2008 | 07:21 PM
johnny17's Avatar
Car: 92 Camaro RS
Engine: SBC Forged 383
Transmission: Turbo 350
Axle/Gears: Ford 9"/ 3.89
Re: v6 to v8 swap
My solid mounts hang over a bit too. I used the three holes too.
I have a 92 RS that came with the V6 and was thinking about keeping the 3:42's when I did the engine/tranny swap but decided to go 3:73's after talking with a few people based on HP and street/strip use (mostly street). After 17+ years you may want to have the rear rebuilt anyway- my carrier bearings were showing signs of wear. Just a thought.
Last edited by johnny17; Nov 26, 2008 at 07:25 PM. Reason: Wanted to add more info.
Old Jan 17, 2009 | 09:34 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
Re: v6 to v8 swap
not to rehash the beaten topic, but i had a similar question and i just wanted to make sure that im doing this build right the first time. i have a 84 that had a 2.8 and the guy that killed the 2.8 sold me the car, had a 305 he gave me with the v8 mounts. so i wount have to drill or modify the k-member? and it will be strong enough for a little stronger than stock 5.0? than you very much im sure this is a newbie question, i just dont want this to comeback and bite me in the rear in advance
Old Jan 17, 2009 | 09:42 PM
five7kid's Avatar
The crossmembers weren't V6 or V8 until they were mated with the mounts, engine, & car. So, no difference in strength, bolt holes, etc.
People have used the stock crossmember for race 350's, 383's, even 454 big blocks. It's plenty strong.
Old Oct 24, 2010 | 03:05 PM
RHolden1969's Avatar
Re: v6 to v8 swap
I have a 98 Camaro. I took out the 6 cyl. and trying to put in a 350 but cant find the right motor mounts. to get it to fit in the car right. any suggestions would be great Thanks
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
