HELP!!!
Old Jan 11, 2009 | 12:53 AM
Camaro <Mustang's Avatar
HELP!!!
Alright bought a 2nd gen that didnt run for $50 bad motor...
So I sold my third gen and bought a 350 for it.
Motor came out of a 1995 chevrolet C1500 2wd p/u and its a 5.7 (duh)
Motor has aprox 98k on it.
ran fine before we tore it out of the truck...
No I pull out the pos 305 and transmission. Hooked up a turbo 400 to the motor, and droped it it. Couldnt get it to turn over, sounded like the flywheel was stuck on something?
take the transmission out, try turning it over by hand.. IT DOESNT WANT TO ANYMORE.. before i droped it in i was able to turn it by hand.
No belts are hooked up to it, distributor is out, and so are my spark plugs, water never came out of the motor so not blown head gasket... maybe cracked head??? ideas anyone??
Old Jan 11, 2009 | 01:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP!!!
It won't turn in either direction?
Old Jan 11, 2009 | 01:29 AM
Re: HELP!!!
No it wont, thats what I dont get. And it should...
Old Jan 11, 2009 | 01:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: HELP!!!
Might have to start taking things apart and see where it's hung up.
Old Jan 11, 2009 | 03:30 AM
Re: HELP!!!
yea thats what im gunna to tomorrow.
Gunna see if I put my flywheel on backwards or not.
Its a counter weight, and then my weight is twords my engine block.
So it might be caught on the block. but im gunna chech tomorrow.
one of the guys in my car club and I are gunna tear it apart
Old Jan 11, 2009 | 03:32 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: HELP!!!
You would have noticed the flexplate was on backwards when you bolted the torque converter up.
Old Jan 11, 2009 | 05:15 PM
Re: HELP!!!
Motor is seized...
Im out $1,100
And nothing i can do about it but drop money into a complete rebuild
Old Jan 11, 2009 | 06:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it ran just before it was pulled, either something was dropped into it, or it wasn't properly protected between being pulled and installed.
